Ok the shocks are now sold.
But the King springs are still up if anyone wants them
They will drop your R32 skyline 2inch all round.
"street-spec" spring rating. They are a very nice ride, stiff enough to minimise body roll, but not so stiff you will loose your kidneys.
Fit onto standard shocks.
They are like new and were only in the car for a few months.
Bargain $200.00
https://www.sau.com.au/forums/topic/19268-r32-king-springs/
how will they work with Bilstien shocks? the spings i have with them are too low even on the highest setting. Ive got 260mm between centre of wheel and guards on highest setting and 360 is the legal limit here in S.A
https://www.sau.com.au/forums/topic/19268-r32-king-springs/#findComment-411222
Well the fronts tended to bottom out with my bilsteins (as pictured above) they will fit fine, the rears are perfect on there, i think you would have to go stiffer than this for the fronts, unless you have a shorter length shock.
https://www.sau.com.au/forums/topic/19268-r32-king-springs/#findComment-411401
