hey guys,
have my rb25 dropped in my 32, and with the previous set up (rb20) it was running a malpassi fuel pressure reg and custom fuel rail. now that im using the 25 and the injectors are side feed, the rail already has the standard reg. i want to use the malpassi and avoid the standard reg. because the standard reg is attatched to the fuel rail, the only way i can think of going around it is to modify the fuel rail? im sure many of you have delt with this before. I ran a search but couldnt find anything specific enough for my answer.
Cheers,
MIKE
https://www.sau.com.au/forums/topic/192978-fuel-reg-fuel-rail/
fairly sure you just buy an adapter, this is what you need to buy when you use a sard reg on them, as they are a seperate reg from the rail, unlike say a nismo that bolts straight on.
you will be able to buy the adapter seperately, just hit ebay or something.
its just bolts on and gives you a normal barb fitting to run hose to a seperate reg.
nismo sell a fuel rail adaptor for standard fuel rails.
Whats wrong with the standard regulator tho?
im going to be running 480cc S15 injectors so the fuel reg will let me bump them up a bit when i need it.
cheers
!!! Thank you! thats what i wanted to hear. nice simple solution. Cheers bud, ill have a search for them now.
this here shows what i am talking about, most people that sell the sard regs should be able to help.
http://www.evasivemotorsports.com/merchant...ct_Code=XA69014
http://cgi.ebay.com.au/Fuel-Regulator-rail...VQQcmdZViewItem
Edited by RB30-POWER
    • It's been quite the ordeal but hey, at least you figured it out.
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
