What did your sister say when she saw her car?
I washed it first, it looked better than when she gave it to me and it had more petrol.
This made her very happy. LoL, if only she new what kind of revs i was doing all day.
I didn't have an trouble with Anthony's... unless they went offline after I looked at them this morning.
Yeah. the little boxes with a red x were coming up.
All good now though!
does anyone have more pics of my car that they can send me?
