A littl while back I blew the ceramic turbos, and had them rebuilt hi flowed with steel wheels. After putting it all back together, it also seems that the engine has suffered a bit from the turbos blowing up - it's down on compression in cylinders 2 and 3 and blowing a bit of smoke (but only on gear changes of whem blow off valves open)
Anyhow, I haven't had the time or cash to pull the engine down for what I understand will be a rebuild at some point in time.
What I do want to know is - and this may seem a stupid question but bear with me, my old man has organised a drag meet/speed trial in my small home country town - he wants as many cars out there as he can, and would like me to run mine, even if it's just a couple of half hearted runs - but lets face it, does anyone ever go half hearted?
What is the chances that I'm gonna do some real damage - like dropping a bearing, or putting some crap through my new turbos?
https://www.sau.com.au/forums/topic/193210-am-i-gonna-kill-my-turbos/
From the soudn of things you will do some serious damage!
If your engine is on the edge then flogging it will more than likely make it go pop. If the turbos are recently rebuilt, then they should be ok. Either way its rebuild time for you. :yes:
Edited by stolen_s15
find out why its low on compression. do a leak down test and a compression test. if its just worn rings then go for it hammer the crap outta it till it dies i say :P
post your compression details
Yeah, I've got the results written down at home, I'll post em up tonight, but just from memory, I think all cylinders were about 145-150, and cylinders 2 and 3 were down by about 10.
down by 10psi isnt a real issue, its not perfect but if the biggest variance you have is 10psi between the highest reading and lowest reading piston thats should be ok.
How many kms has the motor done? What oil are you running? If the motor is just a little tired because of high kms, hence the oil burning, i would still beat up on it.
Change the oil and filter before you go, and have some fun i would say.
I just found the comp results:
All cylinders were 145 - 150 like I said, but 2 and 3 were both at 125.
Not sure on how many kms engine has done, it came from a half cut that also had and aftermarket dash, which had 25, 000 on it. It's an R33 engine though.
Can't recall the specific oil, it's pennzoil I believe, certainly not cheapie stuff.
Sorry that I'm a bit vague, the car is stored at my folks place up country - no parking at my place :angry:
are you running twin turbos on a rb25??
well if the lowest reading is 125 then thats a 25psi difference and thats a tad too much
try and do a leak down test and see where its leaking, ie rings, headgasket, valves etc
if you dont really have the cash to fix it, dont push it then cause by the sounds of things the engine has hard a rough life and is on its last legs. In saying that if it was me i would still be booting the shit out of it, you gotta teach these engines a lesson... :D
if you dont really have the cash to fix it, dont push it then cause by the sounds of things the engine has hard a rough life and is on its last legs. In saying that if it was me i would still be booting the shit out of it, you gotta teach these engines a lesson... :)
It's an rb26, with a set of slides hi-flows. I haven't had a leak down test done, so that might be the next step.
I'm def keen to give it a flogging, and I'm prepared to cop some ring/piston/bore damage, but not so keen on dropping a bearing or valve, or putting some big chunks through the turbos.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
