i Have a 2nd hand r32 gtst 2 way mechanical limited slip differential for sale.
it locks up nicely. it is probably not suited to a daily driver, as it is a lil uncomfortable.
Not sure of the brand...
comes in diff housing ready to bolt in.
serviced recently.
$700
https://www.sau.com.au/forums/topic/193297-2way-mech-lsd/
located in hawthorn melbourne.
the diff does have a lil slack, but it is not really tired, it locks well under load. just bangs around a lil on slow unloaded driving.
never misses a beat when you want it to spin the wheels.
https://www.sau.com.au/forums/topic/193297-2way-mech-lsd/#findComment-3469977
