yeah sure have, works well. but count the bushes down there, there are 16 from memory once you count upper and lower, inner and outer. I think they are all the same. Be careful with the noltec website though, their catalogue was not right when i got them a few years back
i did mine not long ago... was a full on prick of a job to get the old bushes out, ended up using an oxy torch and a vice. Better off taking the arms out yourself then paying someone to remove the old bushes as its just not worth the headache. The new bushes go in easy enough
Removal is a bit of a saga without a press. I drilled through the rubberwith an 1/8inch drill or there abouts and pressed the crush tube out with a vice, then hacksawed a couple of slots in the outer about 2mm apart and used a pin punch to roll that out. It took about 10-15 minutes per bush once i got the hang of it. The trick is to go slow with the hacksaw so you don't cut right through into the arm itself, then using the punch you tear the strip out and leave the arm undamaged.
I found that the lower control arm inner bush numbers in the catalogue to be wrong. There are 2 possible sizes. You need to measure yours before ordering and make sure it gets passed on to noltec. I got the same wrong bushes sent out twice before finally getting the right ones (they were numbered as z32 ones on the packaging).
Installation is a piece of cake. no press required.
i took the factory bushes apart today ,it seems that the only thing that wears and causes the unwanted movement,is the plastic inserts that sit inside between the metal bush and the crush tube,so why cant we just buy these?
dude!
Your picture up top is the rear bushes. You are ripping out the fronts which is a completely different process! And different size bushes too.
There's a collar that you just smack with a hammer and a chisel (or screwdriver) It takes the whole bush out as a unit. They are the easiest bush to remove of all the suspension bushes. You can see the collar in your photo above my last post.
you know its been ages since I've seen the stock ones, but I thought they were 1 piece rubber with a metal crush tube in the center. Looks like yours have been changed at some stage unless I am mad
*disclaimer* I may well be mad
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
