Located in Sunshine, Melbourne. PM or contact on 0402 198 170 - Bryan
Pickup preferred, won't ship anything big.
R32 GTS-T Dump/Front Pipe - Good condition, Stock dump, front pipe is aftermarket 3", Mild steel, o2 sensor not included, bolts up to standard turbo/cat or 3" catback, good for a stock looking engine bay and quiet exhaust! Selling as I fitted a 3" front/dump.
$50
Deka ETX16L Battery - 1 month old, 250cca cranks at 500-750. Have used it to start car 3 times, driven on for 20 minutes at most, compact and lightweight at 5kg~,needs a recharge (I don't have a charger), perfect for boot install or small battery needed after FMIC. Still have original box + invoice. Selling as I sold the car it was in.
$120 ONO paid $220! It's basically new!
R32 GTS-T Tail lights - Good condition, no blemishs cracks etc, electronics all work fine. Selling as I installed L.E.D's. Covers not included. Can get pics if needed.
$50
Bride Superlow Passenger rail - FC3S - Perfect.
$100
HKS Pod filter - 3" Inlet, Yellow foam, could use a clean, or new foam elements are available from sponsors. Comes with silicone joiner
$30
Edited by bryyy
https://www.sau.com.au/forums/topic/193758-skyline-and-fc3s-bits/
Will also have a 3" Catback for r32 Gts-t up for grabs in a few weeks. It is Mild steel, and has a decent muffler and big cannon, has a JASMA badge on it so it isn't too loud at all.
I think it may be a oldschool nismo exhaust? I really have no idea. Chasing $200 for it.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
