Ok, ive looked in other threads but cannot find an answer to my question, which is, is there anyway to disable climate control altogether so it just pumps out constant cold/hot air?
Dont flame me if this has already been answered somewhere plz :worship:
https://www.sau.com.au/forums/topic/193950-r32-climate-control-question/
yeah i remember reading on sau somewhere, tutorial i think, about using resistors instead of the sensors to make the climate controll pump out at full power. i also know that if you hold onto the up button for a few seconds it will flash FH full heat. and if you hold down for a few seconds it will flash FC full cold.
i think it was FH and FC, cant remember, you'll know when you try it.
yeah i find the climate control useless.
Never use the auto setting on the AC. Just always set it to 18degrees and choose fan speed
One question i had was, what if its 16degrees outside and i want cold air flowing through the vents. Climate control only goes to 18degrees.
and the air isnt as cold as outside in this scenario
Does that mean it will pump some hot air out to make it 18degrees?
yeh, mine constantly either pumps out hot or cold air regardless of what temp teh controller is at. It can be quite annoying, but luckily atm its stuck on cold haha so its not so bad. Can Anyone help? Sorry to hijack thread...
haha that happens to me.
I pray for it to get stuck on cold when its a hot day :(
The problem is most likely your blend door servo motor. This controls the hot/cold flap. If the motor is dieing/jammed it will not move the flap according to the temperature you set it to.
To see if yours is working.
Get into passenger seat, stick your head in the foot area and try and look behind the headunit. You will see a metal rod and a white plastic clip attached to it.
Guide your arm towards the hot/cold buttons on the controller, and press quickly up/down. You will then see the white plastic clip attempt to move the metal rod which moves the position of the flap.
If nothing is moving, then its either jammed or dead.
Take it to an aircon mechanic he should be able to diagnose it.
Quote is about $70 second hand motor + $100~ labour to install.
to disable climate control on the R32 is easy.
you hold down the hot or cold button until it maxes out (ie.. 18 or 32) then it'll hit FC (forced cold or f**kin cold, whichever you prefer) or FH (forced heat or f**kin hot). Then you can use the fan button to vary the speed of the fan as it auto defaults to full fan speed too.
if you just want the fan to go on and not engage the climate control, then switch it off (nothing on the screen) then press the fan button. It'll turn just the fan on and blow whatever's outside thru or cycle whatever's inside.
you'll also notice that if you don't turn anything on, a steady stream of air trickles through. if you want to turn it off, then while its off, just press the recirculate button, and there'll be no air movement at all thru the system.
hope that helps... if your climate control isn't workin properly then its most likely that flap... sometimes its easy to fix yourself if its just jammed... I might post a DIY on how to lubricate/clean the lever assembly. I gotta clean my aircon filter this weekend.
oo didnt think about adjusting fan speed in FC mode, will give that a shot!
Wouldnt this blow at the displayed LCD temperature? I press the fan button and then the up arrow and it makes it hot air come out. So wouldnt this displayed temp have an affect on the air coming out?
that really shits me especially when flap is stuck in hot. Get this annoying flood of hot air.
Ive tried pressing the recirc button but i dont think it made a difference? Will give it another try
DIY would be great, not really keen on replacing the motor cause its too much money hehe
just the fan button (press repeatedly to control the speed)... if you press anything else it goes back to climate control mode and pwn's your ass.
Alot of useful info, thanks. My problem is that even if i got it on 18 degrees, it will blow cold air for a bit then blow ambient air for a while, and then cold again. Its not just constant cold air. When i press 'amb' button it says something like 37 degrees. Next time i drive my car, i will try the things mentioned. Thanks again.
Edited by NRV155
I think that could be your system controlling the temperature. Like it reaches 18 degrees when it's blowing the cold air, but when it reaches the 18 degrees, it'll blow ambient air to keep it at 18 degrees not make it go down to 16 degrees or what ever.
Just hold down the 'cold' button for about 10secs or until 'FC' comes on and it should continue blowing cold air like others have mentioned.
i have an r33 but im pretty sure they have the same air con system.
first of all the temperature of the air depends on what mode you have it on or whether or not you have pushed the a/c button.
if its just the fan going it will push out ambient air, if the a/c button is pushed you can control the temp by the red/blue buttons and the speed by the fan button.
the Auto setting is a tricky one to figure out. Due to alot of the sensors in the older cars being screwed and the valves have all either broken or gotten stuck the auto button is usually not worth using imo.
the re-circulate button is the best as you dont get all that annoying hot air coming out at your feet and you will also notice a slight increase in the cars performance and fuel economy.
so basically just use the fan button the turn the air con on then select which ever mode you want. Then use the temp buttons, just avoid the auto button as its just a hassle.
r33 and r32 climate control are very different. r33's don't give you as much manual override as the R32.
In my R32 the climate control works fine, then once i had it set to hot, no matter what i changed on the control screen stayed hot, then few hours later it was working again. Im thinking either the motor that controls the flow to the heater core was sticking or the cabin temp sensor may be faulty, any ideas?
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
