a hollow tube tapered to a narrow inlet with no filtration whatsoever will give yout he loudest noise.
you have an N/A, you won't get any noticeable induction noise unless you use a shithouse pod that has horrible gaps in it that makes a noise as air goes thru it.
http://www.skylinesaustralia.com/forums/No...er-t193696.html
you posted this a few days ago, there is no need to open another thread.
+1
and as funky said, non-turbos wont get the induction sound u want...ur better of getting a megaphone and doing the sounds yourself ;)
lol +3, but this thread really should be closed rather than us complaining there's another thred open lol
lol true, but pva_glue has joined the army and SKY031 is hardly in this section. so there really isn't anyone unless one of the other mods comes wandering in here.
there are so many threads that need to be cleaned up..
Ccould we promote one of us as mods?.. if we uask current mods? Thats way theres always one of us on here?
Edited by GTS4WD
i used to be pretty active in the NA section when i had a gts and an ae86, now that i've sold both I don't really come in here to clean stuff up.
I rection Eug could be a good candidate.
  • 3 weeks later...
+1
and as funky said, non-turbos wont get the induction sound u want...ur better of getting a megaphone and doing the sounds yourself :)
Cut the guy some slack fellas. lol
But look, the fellas have a point... non-turbos will not get the suction and blow sound that turbos get... but you still get the flutter sound... well, not really flutter but a kinda off ppphhhhewwww sound.... I suggest an Apexi power induction sound.
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
