not sure that was what Chris had in mind...
If you want to see those cars in recent competition, I suggest you should all go and look at some photographs of that I captured of both of those cars.
You can see the Black 35GTR here at my photo album.
Edited by Stephen Thorpe
  • 1 month later...
yep, i agree lets see what you got.
Hi, again.. I was abroad and have problems with internet access. So, i'm reverse engineer and specialized on mobile platforms (e.g. translating phones). I have experience in reversing&translating area (for example i was the first in ussr area who translated some well-known brand phone to russian lang). That's why I want to work with you.
Sweet :)
I would give you $100 for a CD/DVD that would translate the menus from Jap to Eng.
I'm sure everyone would give you $100 for the Translation.
The whip is out lets see some progress ;)
Well, can someone send me some existing CD/DVD with firmware, or dump, or something else. Also I want to know popular models and so on... In short, I want have all info regarding your devices :cheers:. Plz, email me - z3rr0w at gmail.com
Best regards...
true....
DVD is probably easier to do, as long as the person has a dual layer burner... which should be pretty common these days.
the problem is the firmware. no one here I think can do that without actually sending the whole DVD ROM drive unit to you (the actual hardware).
and doing so means the person taking off the DVD ROM will loose all AV on the factory nav screen... because that thing is the 'brain' that controls
the whole navigation and trip computer.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
