If you have a map disc, keep it in the unit and make sure it reads it.
If you don't have a map disc, see if you can get a copy.
All the units I have seen with a map installed in the DVD rom were an easy conversion. The laser seems to get dirtier with no disc installed.
Cheers
Andy
hi andy , im from the uk, would this coversion work over here and if so how do i get it ?
thanks
eric
Cheers
Andy
thanks
eric
Cheers
Andy
hi andy
im over in the uk,would this conversion work over here and if so how do i get it ?
thanks
eric
Cheers
Andy
hi andy
thanks
eric
Cheers
Andy
Cheers
Andy
hi andy
im in the uk ,would this conversion work over here amd if so how do i go about getting it?
thanks
eric
any luck with the contacts for uk andy?
cheers
eric
Hi Eric
Send a PM to SAU member "Saihaynes". He is preparing the information on the UK for the developer and can tell you when it will be available.
Cheers
andy
hi andy
not heard anything from saihaynes
eric
Hi Eric
Sorry nothing I can do about the UK. I am only looking after Oz.
All I know is that it is still under development to work out if it is a viable opportunity.
Cheers
Andy
We need a new locked sticky for software: this one's getting large and full of queries.
Perhaps put all the relevant info into a new thread, and let only those involved in the software update it...??
Just a thought.
I will be in Canberra from the 1st May till the 4th and will be able to do language conversions for anyone interested during this time.
Send me a PM if you are interested in getting the conversion done.
Cheers
Andy
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
