If you have a map disc, keep it in the unit and make sure it reads it.
If you don't have a map disc, see if you can get a copy.
All the units I have seen with a map installed in the DVD rom were an easy conversion. The laser seems to get dirtier with no disc installed.
Cheers
Andy
hi andy , im from the uk, would this coversion work over here and if so how do i get it ?
thanks
eric
Cheers
Andy
thanks
eric
Cheers
Andy
hi andy
im over in the uk,would this conversion work over here and if so how do i get it ?
thanks
eric
Cheers
Andy
hi andy
thanks
eric
Cheers
Andy
Cheers
Andy
hi andy
im in the uk ,would this conversion work over here amd if so how do i go about getting it?
thanks
eric
any luck with the contacts for uk andy?
cheers
eric
Hi Eric
Send a PM to SAU member "Saihaynes". He is preparing the information on the UK for the developer and can tell you when it will be available.
Cheers
andy
hi andy
not heard anything from saihaynes
eric
Hi Eric
Sorry nothing I can do about the UK. I am only looking after Oz.
All I know is that it is still under development to work out if it is a viable opportunity.
Cheers
Andy
We need a new locked sticky for software: this one's getting large and full of queries.
Perhaps put all the relevant info into a new thread, and let only those involved in the software update it...??
Just a thought.
I will be in Canberra from the 1st May till the 4th and will be able to do language conversions for anyone interested during this time.
Send me a PM if you are interested in getting the conversion done.
Cheers
Andy
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
    • No sync errors , i have installed AEM disk will return original 360 slot disk and check if there’s any one with running AEM disk could share setup
    • Its been a while! Finally thought to do something on this car, so here we go. This will be a slow burning, multiple posts as I spend 0.5-1hr a day on this job, over multiple days... Full set of GKTech suspension arms!   Step 1: Buy Arms, done! Step 2: Start removing stuff. HICAS was easy. Rear suspension arms are now gone, they were a bitch but breaker bars with long handle extensions, 2 1.5hr slots later, stock arms are off! Next step, remove the hubs and take them to work to press out the bearings and bushings!
