  • Replies 91
Chris - Im a n00b with teh part numbers :D
Thanks for the pics!
I'll take the the brakes thanks mate!
pm sent ;)
can u send me pics of the trust cooler mait,cheers buddy, and whats the diferences like with these direct bolt on trust coolers
Hey Chris,
sorry I havent been in touch, flat out at work and after work.
Next week I can 100% get the rear brakes from you
HI will you take $300 for the R33 brakes? Are you selling calipers and rotors together? If so I will take them.
Edited by polishstorm
