Item: R32 standard mirrors
Age:17 years
Condition:some A1 some good. all work electricly
Price: around $100 a pair
To Fit: (What car) R32 gtst or GTR
Contact: via pm
Comments: i brought a set a while back to fix a broken one. removed them later and replaced with gandor style. one pair has cam off a wreck and one pair is waiting to come off for gandor style.
thanks damo
Avalible in gun metal grey, silver and the grey between gun metal and silver. sorry i dint put this up earlier.
Edited by DJRIFT
https://www.sau.com.au/forums/topic/194406-r32-mirrors/
  • 1 month later...
U have any pics of the gunmetal ones? just wanna make sure they the same colour with my car..
how much delivered to 2250 NSW?
note: after a pair
cheers
i will get pics up late tomorrow of the gun metal ones. the car does seem factory gun metal thoe.
thanks
https://www.sau.com.au/forums/topic/194406-r32-mirrors/#findComment-3592971
  • 3 weeks later...
first post updated with coulor choises. gun metal grey, silver and the grey between the two.
thanks
need drivers side one in black in good condition if any1 has please contact me on 0405073923.
sorry for the hijack just need this bad
https://www.sau.com.au/forums/topic/194406-r32-mirrors/#findComment-3626115
