industrial truck cleaning cleaner called "RIP OFF" if you leave it on to long it will turn them yellow. Also use it on the paint work (quickly) all the bee stains, bird shits ect come off just with water. Again have to be quick otherwise i would have a pale yellow 33 :)
the only perk of work is the cleaning equipment
https://www.sau.com.au/forums/topic/194691-cleaning-rims/#findComment-3489228
don't use rip off on paints that don't have clear over them though (white, red) as it strips the polish.
but yeah rip off works killer on brake dust.. just don't leave it on the wheels as yeh it corrodes them. and high pressure hose at the carwash for example to rinse em.
https://www.sau.com.au/forums/topic/194691-cleaning-rims/#findComment-3489266
soapy water is what i use, have to be careful on what cleaning products you use with chrome wheels ect.
so i use soapy water...
i guy i knew bought a set of chrome wheels for his commy and the day he put them on he went to a car wash and used the high pressure washer and it took the protective layer over the chrome off which left yellow looking marks over the wheel. they were the BSA brand wheels, but this was a few years ago, wheels have come along way in quality.
Edited by 4drftn
https://www.sau.com.au/forums/topic/194691-cleaning-rims/#findComment-3489299
if its just light dust from like 2 or 3 weeks of driving i usually use the TYRE CLEANER from happywash, you have to wait about 30 seconds before the real shit eventually comes out the nozzel but THAT combined with time washing the rest of the car and HIGH pressure rinse, they come up a treat... but most happywashes, dazzlers n shit never top the shit up so forget everything i just said LOL
For the older dust thats been on there for a while you should use some of that elbow grease, always works a treat.
Edited by Ryanrb25
https://www.sau.com.au/forums/topic/194691-cleaning-rims/#findComment-3489328
Couldnt recommend anything better, i just fill up a bucket of warm soapy water and wash away, bit of a nuisance washing the inside (anyone with impuls will agree) but completely white rims look nice. I used "Hot Rims" and it made my discs change to a dirty colour and started squealing after just getting them machined..
https://www.sau.com.au/forums/topic/194691-cleaning-rims/#findComment-3489337
thanks lads!
cos i have gheto spec rims that i painted with a couple cans of black spray paint, to minimise the paint chips n extra work respraying, im gonna try the hot soapy water and a kenco brush... elbow grease is probably the best option :)
https://www.sau.com.au/forums/topic/194691-cleaning-rims/#findComment-3489340
*waits for cara to say permaguard is the shit* lol
but yeah if crome make sure u get something that says crome safe. meguires have a wheel cleaner that is crome safe if needed.
soapy water and a chamois will do the trick.
https://www.sau.com.au/forums/topic/194691-cleaning-rims/#findComment-3489368
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
