I am after info on the HR31 Coupes, specifically the differences on the GTS & GTS-X. No one in Aus can give the actual difference or what sets them apart on the two models, or should I say 4 as they came with the old stove top light (86-late87) and the later with the Aussie style (87-88). I would take any info that was available on these cars. I myself have an late 87 Model GTS/GTS-X and would like to clear up what it actualy is.
thanks in advance
https://www.sau.com.au/forums/topic/19497-need-help-from-japan-on-hr31/
Check this out... go to the 7th catalogue from the right, it's the GTS 2-door at the top, then towards the bottom of the catalogue, you can see all the variants, including the GTS-X.
I CAN read Japanese, if you have any questions, but zooming in on this catalogue just makes the print blurry. Just do a simple cross-check with the pics interior/exterior first, then if you still can't firgure it out, I'll call SuperAutobacs...
The only thing I can see on those pics that sort of give a clue is that the GTS-X has a front spoiler and rear wing, the interior picks are a bit blury and cant make out anything. It would be very much appreciated if you could talk to SuperAutobacs as this has been a long standing conversation amungst us Coupe owners over here. Thanks for this Rezz.
I'd also be interested to know the answer on this one....looking at some of the pics in that catalogue it seems that some GTS-X's didn't have a rear spoiler as standard (!?!?) - look at the silver one on the 3rd page.
I would be better if the specs page was readable as that's probably where the info lies.
BTW Rezz...great info on that sight nonetheless
Yeah, damn that tiny specs page!
I just tried to buzz SuperAutobacs, and as you can imagine, just getting through to someone in the service dept (my Japanese is "adequate"...) was hard enough. The guy basically said *vaguely* "aaah, theres different materials used in the cabin... the GTS-X has a automatic front spoiler... why don`t you bring the car to us?"
I left it at that. I`ll get my wife (shes Jap) to call Nissan. I`m actually going down to SuperAutobacs this weekend for their annual car show, I`ll definately be able to finalize this once and for all then.
Originally posted by SteveL
Interesting...my car has an auto-spoiler, but pretty sure its 'only' a GTS.
He didn't say *only* the GTS-X's have the auto spoiler... but at that stage I knew the guy hadn't turned his brain on to talk to me.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
