Hey all,
was driving down the bay last night to pick up a mate and head into the city, i turned left onto jetty road at the top and changed from 1st to 2nd, the second i did that the cops watched my car and as i turned onto mosely st they did u turn and before i got 10 mtrs down the road and pulled me over. The first thing the cop said, "that was the stupidest thing i've ever seen in front of a cop" note these are his exact words. Not being a smart ass about it i replyed "wat for changing gears" and he didnt say anything. I had the car at no more than 3500rpm before i changed gears. Then he got his little meter out for noise and did me for 110db at 3200rpm. After not being able to find anything else he got shitty and slapped that sticker on there within five minutes. This is my little rant, Jus not happy... My warning to every1 tonight stay away from the bay cause i saw countless other cars being pulled over, that were only modified and getting defected.
But on another note, is there any1 that could please lend me a stock exhaust, and springs asap, and i'll provide some cash or a carton for ur troubles. I have a R33 GTS-T 94
https://www.sau.com.au/forums/topic/195000-defect/
  • Replies 43
yeh my cars been getting picked on by the cops these last couple days..friend was driving my car down main north road and cops pulled him over said they were looking for a stolen skyline, and yesterday i was just driving along then cop drove pass quickly did a u turn and pulled me over i was shitting it lol but luckily no defects
https://www.sau.com.au/forums/topic/195000-defect/#findComment-3494373
Curious, what kind of zorst you got?
I've got a standard exhaust here for an R33 GTS-t you can borrow if you want....
3 Inch Cat back Exhaust System with Dual Apexi N1 Mufflers
3 Inch Race Cat
yeah i have my car booked in for monday so got my work cut out for me.
need to change,
coilovers to stock suspension
exhaust
and to make it look as stock as possible change my wheels
headlights and lil bits and piece's
Edited by Kieran
https://www.sau.com.au/forums/topic/195000-defect/#findComment-3497565
3 Inch Race Cat
need to change,
exhaust
If that's your engine bay in your avatar, I'd say you have a fair job ahead of you.
https://www.sau.com.au/forums/topic/195000-defect/#findComment-3499778
i had a stress when doing some car park maneuvers in front of 3 bike cops that were eating brekkie at maccas yesterday. i was gonna wait till they left, but the shock sensor on my alarm kept on going off from the trucks driving past so they were already staring at my car.
i thought fk this im outta here while they are still chowin down, tried to do the casual minimal noise exit from the car park but my 2way lsd had other ideas with a few little chirps. i was freaking about a defect, so i was shifting at about 1800 rpm up south road
https://www.sau.com.au/forums/topic/195000-defect/#findComment-3499840
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
