Hi guys
Just a quick question, does anyone know how much approximately power loss is there from the engine to the rear-wheels in a Skyline??
I got told it is about 80% but is this general for all rwdrive cars??
It seems that alot of the guys here have their car dyno and just wondering what was the reading for the engine output compare to the rw output.
The reason I ask is that i went for a spin in my car (R33 GTST) with a G-tech meter and got a pretty low hp reading. It was only like 170 hp at the rear wheels which in kilowatts is about 120 if my calculation is right.
That's in a car with me and one passnger, runing 11psi with catback exhaust.
Any input??
Cheers
https://www.sau.com.au/forums/topic/19525-power-lost-from-engine-to-wheels/
With those G-Techs it's important to get the weight and other factors correct. But even so, they aren't that accurate. A dyno is the only sure way, but even still...different dynos on different days will give different results.
I have heard that the power lost from the engine to wheels is about 15% on a RWD car. On an AWD it's a bit more, like 20% or even more. There has always been a lot of debate about this. Whether it's a certain %, and if so what %? Or is it a fixed amount of power and not a %? I don't really know if anyone really knows? :)
The reason I say it is low Dan is because if (my theory haha) a stock GTST has 185kw at the engine and if there is a 80% power lost through drivetrain etc. There should be still 148 rwkw right?!?! 185X.80=148 or am I mean to minus the 148 to 185?? That's mean it is only 37kw@rw!!
That's is why I think it is abit low I was hoping that my car would have maybe close to 190 kw at the engine hehe
Cheers
But how many skylines actually have that amount of power? Brand new, yeah. But after a few years, things don't work as well, rotating parts don't spin as fast and make as much power...etc.
Hiep: Nah, I'm pretty sure that a RWD loses no more than 15%. Some people say AWD lose more like 25%.
Damn I want a chaser!! How much are they? $50k? Too much!!!
Well when I first had my EVO4 dynoed on an AWD dyno, it only put 123kW@wheels on 11psi. Then on 16psi is pumped out 155kW@wheels. Seeing that a standard EVO4 is supposed to have 206kW@engine, which I'm pretty sure mine didn't...it's still a huge power loss. For RWD cars, I'm not sure. But again it depends on temperature as well, cos at the time it was at the beginning of the year and the weather was still pretty hot. I'm sure a few more kW could be had on cooler weather.
The 'rule-of-thumb' is around 30%.
EVOIV, the G-Tech is supposed to be remarkably accurate. But it has to be set up properly.
I had a run up on AVO's DTS dyno. This dyno is supposedly capable of calculating fwkw from rwkw.
My R32 GTS4 (RB20DET 4WD) ran:
115 4wkw
145 rwkw
175 fwkw (calculated from rwkw)
Do the calculations of loss yourselves.
I still think 20% to 30% is a little too big.
Hiep: At one stage my car had 206kW@4wheels, but that power was recorded on a dyno (at the wheels). To record power at the engine, you would need to take the engine out I believe?
If I account for a 30% loss, that makes it around 290kW@engine. Almost 400hp.
In a recent motor mag:
Dyno Dynamics Dyno:
*Ford Falcon XR8 5.4 V8:
260kW @ fly, 193rwkW, 24.6% power loss
*Holden Monaro CV8 5.7 Gen 3 V8:
235kW @ fly, 189rwkW, 19.6% power loss
*HSV GTS Coupe, Gen 3 V8:
300kW @ fly, 222rwkW, 26% power loss
*HSV Clubsport Gen 3 V8:
260kW @ fly, 196rwkW, 24.6% power loss
*FPV Falcon GT 5.4 V8:
290kW @ fly, 225rwkW, 22.4% power loss
*Ford Falcon XR6 4.0 inline six turbo:
240kW @ fly, 185rwkW, 25% power loss.
Consider a RWD car loss between 20 - 25%.
Quote:
Hmm...interesting figures there.
It's kinda weird cos one time I saw a figure of an R34GTR that was dynoed as RWD and AWD and the readouts were the same!???
This should be true, as i understand. GTRs are basically RWD until they detect rear slip (on a dyno there shouldn't be any), at which point a power is apportioned to the front wheels. So the difference should be negligible between RWD and AWD for a GTR.
Hey Skylineakt - did you get any 0 - 100kmh or 1/4 mile figures from the G-Tech. Would be interesting to know what they are cos it will give a good idea of whether your car is performing ok.
I believe you have to wiegh your car before using the G-Tech. Don't just use the factory wieght figures. You have to consider driver and a passenger if any and the amount of fuel should be similar when u wiegh it and test it on the G-Tech.
25-30% .. that is why when you work out the power/weight ratio of say a modified skyline to any of these "top" aussie cars, the skyline still comes out on top.. on the street its pretty much the same I've found. Its all about the weight, and the aussie cars just keep getting heavier and heavier.
Ronin: interesting figures.. thanx for those.. so much heresay.. unless its all measured in a proper testing environment (e.g. same dyno) its hard to compare apples with apples.
Skylineakt: There is talk of a dyno day in melbourne with the VIC SAU crew. Al said he'd try bringing some vehicle scales so we can do some interesting calculations as well as receive dyno figures. Get along and find out for sure - it should be within the next couple of weeks.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
