Dumb Stuff You Just Shouldn't See On The Road!
  • Replies 250
.....funny as heck when my mate test drove it.. the looks from people at the lights as it 'lumped' its stupid butt off! He never bought it! But he really thought about it!
wrong....no one but me ever drove that car.
It no longer exists, the engine is now in a commonwhore.
Cheers
Jason
WRONG! the car i'm talking about was about 8 years ago! Blue 253 holden, quadrajet, 2.5 inch exhaust and a half cage, and it was all engineered approved. had (if i can remeber right..)a toyota 4 speed behind it! It went very well.. but he just couldn't bring himself to owning a poo coloured datto! I remember it well because he hit me up for a loan to help buy it.. I was all for it.
I never said i was talking about the same car..
not as bad as 180's and silvia's.
i welcome making skylines the new commodore. means more research and development will go into their products. further increasing their market share and as a result... decreasing prices...
=economies of scale :D
doesnt an s15 say silvia on the dash?? even the aus spec ones? Just trying to remember from my bosses car
Yes on the passengers side...
says silvia on the headlights too
And also on the side steps as you enter the car the word "SILVIA" is etched in stainless... :P
The standard gear stick knob also has the silvia's "S" on it...
Who really gives a crap about silvia's anyhow?
speaking of them.. If I owned one, I would put another engine in it! Just to piss ALL those SR freaks off! something like.. umm.. probably a toyota engine!
Of all the car brands that i have seen modified by their owners, the old silvia has to be the most modified, but buy far the poorest!
Really big turbo's that don't make boost until 5500.. or later, those stupid little BOV's that don't flow air (they just make a horrid noise) and exhausts that sound like a bumble bee has farted in a storm water drain.. and then there is the suspension!
When you are finished playing with your toys.. come play with the big boys!
Thats gotta leave a mark. :P
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
