i have a big FMIC, 700hp fuel pump, GTR injectors, custom piping, custom exhaust with split dumps off each turbo, running into a 3" system, through a 3" hi flow cat, adjustable fuel pressure reg, microtech LT8 with handset.
i think he said boost, if i wanted 200rwkw he said u'd need much more boost *shrugs*, lol. At the moment i can't really afford another re-tune so im stuck.
sif big FMIC! Mines bigger!
I can say that Jao's car is a bit of a lag beast (from what ive seen) and traction sounded like it was an issue when he fanged it up the hill, but its cool and im shitty that he has a RB20DETT and i dont! :P
  • Replies 141
my gtr greddy manifold was modified in japan to fit an rb20 by simply welding, machining and drilling extra tangs onto the flange. the ports still line up perfectly.
ie instead of \ \ \ / / \ its now \ \ \ X X \ (yea dodgy explanation but i'm sure you get it) :D
lol, sproosy, posting again i see :)
Yea i'd love to get some help to extract every single extra kw out of this thing, as it seems to be, well, under powered, any help/ideas/places to go for help? roy? :)
LOL...I dont know. :D
I am curious to know what turbos it has...can you see any markings on the housings?
on mine? Standard 32 GT-R turbos i think, suppose i could take a sticky beak if you want.
Any suggestions on what to do next to get best gains and smooth out the power curve?
Well, call me simple minded, but R32 GTR turbos have been good for 220-230rwkws at 1 bar on plenty of GTRs...i wonder why they wont make similar power on an RB20....(note i said similar power, not the same power)??????????
Microtech LT8, they can be tuned via laptop cant they? Got a copy of your tune, what sort of ignition and fuelling does the engine have. Also have you got air temp compensation wired up and tuned for?
Id say dump the cat, and have a look at the tune. My R31 GTS-X made way more power once a decent tuner had a look at the MT8. Also have a look at your battery voltage when driving next at night. My car with the MT8 went from a pretty strong 200 odd rwkws to a doughy piece of lard as the battery voltage got into the high 11s as the ignition system gave up the ghost.
A new battery, and a big ass Bosch alternator had the thing putting the numbers down way more consistantly. Are you sure your tuner knows his way around RBs running Microtecs?
Not sure of his reputation with microtechs and RB's, it isn't a very common combination. Currently tuned by Greg at Autosport Engineering in Kirrawee (Sydney). THINKING about going to Thornleigh Cylinder Heads (huge reputation, but pricey) or UAS.
Would getting rid of the cat give any worth-while gains though? My voltage sits on around 9.9 i think(or 12.1, i really can't remember). Not sure about the air temp compensation, i'd like to look into it though as i want to explore every single possibility to extract more power out of this, long term project, hoping to crack 300+ rwkw from RB20/24(maybe).
The biggest downside at the moment is that i got the car with the microtech already in it, so i can only guess what the previous tune was, and what it has and hasn't got, so in a way, im starting from scratch, well, a more painful process.
If your battery voltage is dropping that low then i would hazard a 6 pack on the fact that your car isnt making the power it should because the ignition isnt working 100%.
The MT8 was very sensitive to battery voltage, and the igniter drivers in the ECU needed a good strong voltage, otherwise the car ran like adog. The car was always a bit doughy, the car never really made much power considering all the gear on it. Then one day i noticed on the handset at night that the voltage was lower (stereo going, lights and windscreen wipers) and the car was slower then normal.
A few questions to the right people confirmed that they need strong 12V+ voltage...the car was great once with a new battery/alternator and a good tune from Quickfit in Hornsby
so are there any other places you can reccomend to tune a microtech on an RB20 in sydney? Reasonably priced too (can't get it done yet as i just bloody forked out $1100 for work on the car including a full dyno tune :D)
I havent tried many, everyone has their favourites. But i did find Quickfit (NSW Autronic dealer) very good at getting my car to drive a lot better and make better power...cant really remember what i paid, it was 6 years ago :D
Then again, it could be tuned perfectly, and thats the power it makes?!?!?!
*shrugs* i doubt it. It runs very poorly on coldstart, i know microtechs are notorious for this, but it can't be THIS bad, i don't know, i just have my doubts, i know it can be more finely tuned, well, i have a gut feeling.
Try unigroup at girraween. They have tuned a lot of rb powered cars and offer good prices.
As the car is running, it will likely only be a bit of a touch up (depending on how the current tune looks) so you could get a surprisingly cheap quote.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
