I bought a 1993 nissan skyline hr32 gtr v-spec this year in march. Since buying it and being the first owner in austailia.I noticed faults with the car like the engine cutting out after accelleration and pinging noises coming from the motor. I had the car inspected buy 2 independent repaires.The first repairer told me to take the car back to were I got it from because of engine oil leaks (they had trouble locating),faulty suspension and a leaking brake line.The importer then fixed these faults and told me that the oil was splashing out of were the oil dipstick is located and it was because of the way the engine rotated and it just need to be fastend down.The car was then involved in a minor accident and had front end damage.The importer told me to get it repaired down the road from his workshop at the panelbeaters were he got his cars repaired.I picked the car up from the panel beater after repairs and on the way home the engine detonated and smoke started to come from the exhaust.I had the car inspected buy a second indepented repairer who told me the engine had oil blow through and was wrecked. I got the guy who imported it to rebuild the engine.He told me he would get a second hand block which came with a warrenty and use all new parts bearing,rings,gaskets etc.I got the car back off him after the rebuild he told me not to take the boost over 1 bar and to bring it back to him after I had done 1000kms for a oil filter change. I did that and about a week later was on the freeway driving the vechile and a poping sound came from the motor I heard noise of something going through the exhaust then it stared blowing white smoke everywhere.I had the car towed back to the importer straight away.He had the car for 2 weeks and after ringing him numerous times he told me that he would not cover the engine for a broken piston and that it was my fault for not getting the vechile dyno tuned.He sold me the vechile without a computer making it imposible for accuret dyno tuning.I told him when I got him to rebuild the engine that I wanted him to do what ever it takes to insure my car wouldnt have anymore problems.I have now taken legal action any advise?
https://www.sau.com.au/forums/topic/195618-1993-hr32-gtr-v-spec/
My useless advice would have been join this forum months before you buy a car like this to know more about not getting caught out like this!
My second word of advice is to use proper punctuation to allow for easier reading and take notice of the inbuilt spell checking function to fix misspelling.
Third, your screwed if thats your story in court. A vehicle with no ECU cannot run for a start!
white smoke blowing sounds like a blown turbo from running boost too high
stock ecu should handle 1 bar boost easy as all ya need to do is remove the restrictor without using a boost controller to get that
My thought was turbo exhaust wheel too, with white smoke and the sound of bits going through the exhaust.
was the car driveable yet shit after this, or not at all?
if a piston has been munched then its the fault of the rebuild... Did you get receipts for all the parts?
yo, he told you "not to take the boost over 1 bar and to bring it back to him after I had done 1000kms for a oil filter change" right, did he tell u you would need the new ECU before you could drive it?
Is it using standard turbo's? If your running standard boost, on standard spec internals with standard turbo's then you having a boost controller won't make any difference..
Im guessing you only had 6 months warrenty on the car and that it has run out?
I have a feeling you will win this one because the car has been dodgy from the start and you bought the car with the boost controller, so it is not up to you to tune anything. The car should be roadworthy to drive once it left the importer.
If you installed the boost controller or modded it in any way then you will probably be screwed.
From my understanding after purchasing a car a few months ago your warrenty is paused from the time you return the car back to the car yard for repairs and starts again when it is back in your hands. So lets say you buy a car and drive it for a week and return it to the car yard for repairs and they take 2 weeks repair it. Even though you have owned the car for 3 weeks you have only used 1 week of your warrenty due to the other 2 weeks of it being back at the car dealer getting repaired.
Hey hey turboX Dont be so harsh on him hes obviously not as smart as you when it comes to things like this.. we should be helping him not bagging him .....
good luck
Jason if you need anyhelp Pm me ... I know people who have gone through this sh**
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
