Well since no one else started a thread (west...)
I'm leaving saturday morning...usual stuff
Meet at Shell Service Station, Hume Hwy, Donnybrook - Depart 6:30am...
Usual breakfast stop at shep maccas...
I'll be in the black s15 of course..
Craig(espo)? West? who else??
https://www.sau.com.au/forums/topic/195697-deca-convoys/
hi,
as the saturday is going to be roasting we need some assistance with esky capacity
i can only fit 3 eskies in my skyline. can someone (anyone) please bring 1 large esky, standard size
please post up here if you can bring one so we don't get 18 people bringing eskies
but if someone could bring 1 up or even 2 at the most, that would be much appreciated
your generosity wont go un-noticed
thanks
https://www.sau.com.au/forums/topic/195697-deca-convoys/#findComment-3505024
LOL Gareth - at least your organised!!!!
You can use a AASA license for the day (its cheaper), but you arent entered and im not quite sure what the go is entries at this stage.
If you are serious about entering, PM Snowman ASAP to tell him youd like to and see if he can maybe work something out for ya.
Hope to see you up there, even come up and spectate if you have nothing else on.
https://www.sau.com.au/forums/topic/195697-deca-convoys/#findComment-3505167
Meet at Shell Service Station, Hume Hwy, Donnybrook - Depart 5:30am...
You're the man, thanks!
I could start one but i kept forgetting the Shell servo's name.
https://www.sau.com.au/forums/topic/195697-deca-convoys/#findComment-3505273
I was planning to cruise past there about 6.30. Do I really need to leave any earlier as I have to pick someone up?
It's been a while since I've headed up Sat.
https://www.sau.com.au/forums/topic/195697-deca-convoys/#findComment-3505358
hey all, i'll probably join you on this.
i was thinking of going down the back way up the melba and stuff, but it looks like it may take longer even though it's less km from my place by about 15km.
hmm... maybe i'll get the twisties on the way back...
https://www.sau.com.au/forums/topic/195697-deca-convoys/#findComment-3507069
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
