i agree keep the badge on, its not bad, and cept for the occasional f00 askin u why u have a renalut badge on the car it should b ok.
Unless you completely debadge the entire car for that "wtf is that?" look
https://www.sau.com.au/forums/topic/19570-s-badge/#findComment-411875
Originally posted by funkymonkey
nismoR34... luv ya work! i've been looking all over for pics of the R34 badge so I could vectorise it for the SAU cap... hallelujah...
expect a badge on the cap fellas.
:mad: happy to help out ;)
but I dont know if the top one is a 34 badge or not ?
it looks similar to mine ~ i guess
https://www.sau.com.au/forums/topic/19570-s-badge/#findComment-411882
yeah same on mine, no stickers nuffin on the back, jus the S on the front. looks sweet coz no one can tell its a GTS, cept for the blue GT badges. (the wheels are covered so no one can tell how many nuts its got.)
https://www.sau.com.au/forums/topic/19570-s-badge/#findComment-412268
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
