hey guys as you know i had a crap slide hiflow that chat itself under light load.
And as i was expecting.... not under warranty!!
just thought id let ya guys know incase somthing happens to your slide hiflow .
"something went through the turbo"
man that makes me laugh :laughing-smiley-014:
oh well onto bigger and much better things :P
cheers
nothing wrong with bush bearing Tony.. its just that the person/company that did yours might of done not the best of jobs?
but as you said move on to bigger and better things
best of luck
yea exactly
And thanks
nuthin went through it. i can assure you. how can something go through when everything was tight, in tact, and perfectly meshed afm .
I shouldnt have sent it to THEIR workshop for warranty. A new company took over called murnane. As if their going to warranty sheldons shit hiflows... well... "aarons"
Be careful guys... be very careful if yours goes pop on you
not trying to bag Aaron but i had a very hard time getting my turbo from him and after i asked for a refund that took 2 months, if your going a new turbo i would suggest Kyle from 6Boost top block and very quick delivery, cheaper and supports customers.
A bit of topic but my 2 cents
Edited by axe s
So how did they determine that something definately went through the turbo?
Can they conclusively document and prove that that was the cause of the turbo failure?
I wouldn't be letting ~$900 get away from me without concrete proof of the reason given
Oh and taken from security's thread, if you hadn't sent it back to their workshop and sent it somewhere else then it would have voided the warranty anyway....according to them
Seek a lawyer for yourself and go through small claims. You'll be presently suprised that it won't be that expensive. It will work out less than what you paid for your turbo.
Let a court decide based on THE LAW, instead of letting him decide on whatever arbitrary reason he BELIEVES is the law.
I think that its too easy to just say, oh, something went through the turbo. But in reality, r33god was using an air filter. there's nothing that went through it.
Essentially, by not upholding his warranty, slide is just opening himself up to legal action (the ACCC may back you up with costs as well so it may not cost you anything), not to mention ruining the name of his business.
Edited by MANWHORE
Geez, sounds like a pretty shit situation...
Good luck if it does end up in small claims mate.
Doesnt sound like youll need it though with the obvious evidence (in tact air filter and AFM mesh) on your side
mate i feel for your situation, but i think starting a thread like this is going to do nothing to help you
aaron has every right to deal with customer complaints through PM, hell if it were me i wouldn't want my name being dragged through the mud
every company has their issues, but airing it on a public forum is not the right thing to do, on top of the fact that it's against forum rules.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
