I bought my s2 R33 a year or so ago and it didnt come with a spare tyre bolt thing to hold the space saver in the boot.
Every time I go over a bump the space save likes to move around and make noise.
Where can I get the bold to secure my spare tyre and how much will i expect to pay?
Mark
https://www.sau.com.au/forums/topic/19594-when-can-i-get-a-spare-wheel-holder/
Yeah a hardware store is a bitch. It's not like we can reverse our cars into the store and mix and match bolt lengths and threads to get the right one. Also I think you need some sort of metal plate for the bolt to sit on if it's like other cars I've seen.
Maybe try www.findapart.com.au. I'll send them a request too I think.
Yeah will do, I'll ask if they have 2 if/when they reply. I think I might have tried the above URL before with no success, just can't remember if I did it after I got the car. I've used it before with mixed results for other car and motorcycle parts.
I rang up Col Crawford (located on the northern beaches) and they said they can order them in from Japan. It will cost $16 and must be payed up front.
I'll go and order mine tommorow.
The guy also said its the same part as that on a s15.
Jimx: i'll PM you about this.
A wrecker replied to my Findapart request and said he had them for $20, so I replied and asked him to COD one to me. But he hasn't replied in over a week so I guess it's not coming. Oh well, his loss and my gain if I can get one new for $16 :D
Get out a ruler.. measure the bolt diameter, and bolt height, and find an appropriate washer to hold it all down.. its not that hard! Will cost you $3 max via that method.
But if its same as from an S15.. just go to Nissan directly.. they'll have one in stock.
