Not entirely sure there mate, if you selected a larger compressor say a 25g and had a 8 cm exhaust housing with external wastegate and dump and 3 inch exhaust i think at full boost she would be RUMBLING it would be awesome than all u would have to do is find the nearest COP shop.......... sit at the lights REV drop slide round the corner let the waste gate open on a saturday night!
  • Replies 44
Anyone?
If i had my time again i would go a 90 or 100mm exhaust. I have always been too scared to plumb back the gate because of fear of losing some response and power. I know a few ppl that have noticed a drop in power. With everyone else bagging at least and exta 50rwkws then me these days at the track, i dont want to surrender a single kw. And i dont want to spend $300 plumbing it back up only to have to go and modify the exhuast at further expense.
Only thing is if you go too big you could end up with a droney exhaust note????
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
