Hey,
I need bigger injectors bad as under full load i'm hitting 97% on my injector duty. I don't really want to go to the trouble of putting on a fuel rail. I kow you can still get big injectors that screw in and I guess my question is what is the biggest size CC injectors I can fit into the RB25DET.
Cheers. She needs juice. lol
https://www.sau.com.au/forums/topic/196636-bigger-injectors/
Nismo 550's will be more than enough for your turbo (they support 300rwkw no problem).
Largest - I used Nismo 740's for mine 369rwkw.
Stock Rail, Stock Reg etc etc.
I think Sard's in the 800 are also direct-ish fit
396RWKW!!! Thats massive man! What are you running?
Cheers for the advice. I cannot wait to get all the kit on. Iv'e gone a bit silly but whatever yeah! Not long till all the parts come in and i'll be aiming for around the 290 RWKW mark. To tell you the truth i don't really want more than that. I still want to be able to drive her on the road.
Cheers
Kane
Why do tuners tell me to get bigger then 550cc if they can handle 300rwkw
im looking at between 240 - 260 rwkw
Highflowing injectors are abit cheaper then getting aftermarket injectors but i hear they arnt as good, can anyone confirm this?
Edited by SLYNE
Because they are full of shit :D
No other reason, or they are trying to sell you something that you simply do not need.
Because they are full of shit :P
Nismoid,
As I am at the stage of installing a whole heap of gear I need to make sure I make the right decision when it comes to Injectors. Can you point me in the right direction as to where would be a good place to get the standards flowed. Or even someone to talk to about this.
Thanks Mate!!
A good option for cheap injectors is 480cc ones out of manual S15's, they are a direct drop in for R33 RB25DET's.
I'm aiming for approx 260rwkw and 6 of these will easily suffice, and only costing me $280 delivered for all six.
Edited by stolen_s15
Nismoid,
Thanks Mate!!
There have been a number of threads with suppliers/prices and so on.
Just search with "hi-flow" "injectors" and you'll be right
Personally i wouldn't use hi-flowed injectors.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
