Make: Nissan.
Model: 180sx
Milage: 140,000km
Transmission: Manual
Colour: Gunmetal grey
Complied? Yes
RWC supplied? No, car is wrecked.
Currently registered? No
Price: $2,600 neg!
Comments / Modifications:
Time to sell my 180 wreck.....
I will NOT be seperating any parts so please do not ask. Here are some more details....
- 1989 CA18DET 180sx.
- Gunmetal grey.
- About 140,000km's on the clock.
- 5spd manual.
- Has a lukey muffler/cat back.
- Pretty much stock car.
Now as for the damage....car was hit on the front driver side. This caused the driver strut tower to be pushed in, and the wheel was pushed into the drivers footwell (refer to pics).
The engine seems to be pushed over a cm or two. I havent had the engine running or anything after the accident, but after i was hit, the engine was still running (i had to turn it off). However, the throttle body got jammed open, and now the throttle body is stuck.
I will take some better pics on sunday when i got to my dads place. This wreck would be ideal for an import wreckers or something like that, as im NOT going to be stripping any parts off it, so please dont ask, wreck is being sold complete! This 180 was extremley clean before the accident, never had one mechanical issue with it in the year i owned it, and it took me 7 months to find such a clean example!
Any other questions, just ask.
Located in SE suburbs of Melb.
Not sure what price to put on it, but for the time im going to say $3,000 neg. NOW $2,600 neg
Thanks,
Will.
https://www.sau.com.au/forums/topic/197074-180sx-wreck-for-sale-ca18det/
  • 4 months later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
