  • Replies 49
Nope - not ready until Thursday night.
I will let you know as soon as I have them.
You both work late shift in city yes? I can come past after carwas on Thur and drop them off.
But yeah - nothing before Thursday night. Windscreen stickers should arrive Thursday morning.
