very nice
Powerball tomorrow for you punters $22 mil
life could be a dream sitting in that machine
Yeah, I bought my ticket on the off chance I can buy myself a GTR for christmas :banana:
If I actually win the lottery and can buy msyelf a GTR, ill donate my 33 gtst to SAU for a raffle or something :)
https://www.sau.com.au/forums/topic/197257-it-has-begun/#findComment-3529801
Yeah, I bought my ticket on the off chance I can buy myself a GTR for christmas :P
If I actually win the lottery and can buy msyelf a GTR, ill donate my 33 gtst to SAU for a raffle or something :P
haha better keep your word! :devil:
https://www.sau.com.au/forums/topic/197257-it-has-begun/#findComment-3529842
86k was base model price wasnt it? this ones "premium" :devil:
not to be confused with the top o the line "super awesome luxo of fastness crazy best model of much joy!" i hear thats going for like 150k
https://www.sau.com.au/forums/topic/197257-it-has-begun/#findComment-3530119
Would purchasing this car and bringing it over work out cheaper than buying one locally when it arrives? Cause aren't the 35's being sold in Australia the 'shity' versions? How much are they going to be going for? I assume this is the 'better' version of the GTR and if you work everything out, would it be a better buy? Does that make any sense?
Sorry if it sounds like I'm talking shit, I haven't been keeping up to date with the release of the 35 GTR.
https://www.sau.com.au/forums/topic/197257-it-has-begun/#findComment-3530349
Noway it would be cheap bringing over here.
I'm sure compliance can be worked out but, tax and duty would jack that price up so much, plus all the other fees.
150-180000 landed.
Whats the price over here?
https://www.sau.com.au/forums/topic/197257-it-has-begun/#findComment-3530457
i thought you could only import a car thats on the approved list of imports... otherwise it will be rejected... unless of course you import it as a race rally car which can never be registered... ever.
https://www.sau.com.au/forums/topic/197257-it-has-begun/#findComment-3531774
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
