Basically I am about to take my R33 form 231rwkw to around 300rwkw. My question is how much power can the stock box and drivetrain take before things go bump in the night. I already have a heavy duty clutch that apparently will take 300. Any input would be much appreciated.
There is no solid answer.
It will depend mostly on the current health of your box, and what you use the car for.
But 300rwkw for street duties if your box is in ok condition should not be a problem.
think of it this way. JET200 uses a rb25 box and pushes about 315kw.
and has a r33 diff. it worked well man. but why not just plop in a 1.5 or 2 way for insurance.
Thanks for the advice. I figured as much but thought i'd be sure. The car is only 89000 on the clock & the box still feels strong. I do need to get a service on it as i can feel the syncro's when i shift into second. I think i might see how much it would be to get it strengthened while it's out of the car.
Man I'm shitting myself with the amount of $$ i'm starting to clock up on this puppy. Oh well you only live once right. At least she will be a mad setup when its completed!
Cheers
369rwkw i ran @ the drags through my 33 box. no problems... but then i didn't have much traction which is also a factor
Wholy shit! what does she run? have to be 10's yeah. Awesome Nismoid. You freak. lol.
I am not looking to push the envolope that far. Be happy with 300rwkw on streets! I'm just in the process of talking to a mob called Custom cars to finish off all the work.
I'm getting
Tein Coil over
Slotted rotors
Oil cooler
Oil filter relocation
Apexi Power FC boost controler
HKS 740 injectors
Plenum
Exaust manifold
Throttle body
Alloy radiator
Bigger cooler with custom pipeing
Not to mention the container of Carbon we have coming from China. Sweeeeet.
You know of any good shops in S.E Melbourne who are reasonably priced????
Thanks for the advice anyway Nismoid. You obviosly know your shit.
Driveshafts will break long before the diff centre. The VL boys are running 9.50's with a stock R33 5-speed and single plate Jim Berry clutch now so your power expectations should be nothing to be concerned about.
They are smashing third gear eventually though, it all depends how hard you thrash it. 300rwKw will not be an issue and if you want a cheap way out with the rear end throw in a GT-R diff + larger shafts.
Edited by PJ.
  • 5 weeks later...
Cheers mate.
I thought i'd have a look at the oil in the box anyhow and f*ck me. I'm going to have to strat looking for a new box soon. Heaps of metal fileings and even a couple of little like clips. 4 of them. That would explain the crunch i get into 3rd & 4th on full boost. Man I hate this crap that comes and bites you in the ass.
Considering your Melb... some of your mods will get pretty nasty if you get EPA'd... going to cost you a LOT of money (many thousands) to get it passed.
There might be a smarter approach (tha potentially will save money/hassle) :blink:
That said, go visit RE Customs (Springvale), they have been doing great work and are probably the closest off the top of my head.
Here's a tip...... they're never complete!!!!!!!!!!!!!!!!!!!!!!!!
There might be a smarter approach (tha potentially will save money/hassle) :)
Cheers Nismoid.
I am doing my best to keep it all looking stock as possible. Well excluding the carbon mods. It is a bitch of a thing. The good thing is I'm in the Army reserves and My ID normaly gets me out of those sticky situations. lol. Another good thing is I do know of a dodgy russian workshop that'll pass anything within reason of course for $150. lol. Sh!t how do you think I got her on the road in the first place. lol.
Cheers heaps for your advice.
Currently I am having an absolute nightmare with my sound install. It's 5 days since the guy said it would be done. I went in last night and lost the plot. He was like what do you think of the boot. I said SHIT how the F*ck am I supposed to show this. Ahhhhhhhhhh. I wish I just paid the full amount and got a well known mob to do it.
Lesson learned there.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
