Basically I am about to take my R33 form 231rwkw to around 300rwkw. My question is how much power can the stock box and drivetrain take before things go bump in the night. I already have a heavy duty clutch that apparently will take 300. Any input would be much appreciated.
There is no solid answer.
It will depend mostly on the current health of your box, and what you use the car for.
But 300rwkw for street duties if your box is in ok condition should not be a problem.
think of it this way. JET200 uses a rb25 box and pushes about 315kw.
and has a r33 diff. it worked well man. but why not just plop in a 1.5 or 2 way for insurance.
Thanks for the advice. I figured as much but thought i'd be sure. The car is only 89000 on the clock & the box still feels strong. I do need to get a service on it as i can feel the syncro's when i shift into second. I think i might see how much it would be to get it strengthened while it's out of the car.
Man I'm shitting myself with the amount of $$ i'm starting to clock up on this puppy. Oh well you only live once right. At least she will be a mad setup when its completed!
Cheers
369rwkw i ran @ the drags through my 33 box. no problems... but then i didn't have much traction which is also a factor
Wholy shit! what does she run? have to be 10's yeah. Awesome Nismoid. You freak. lol.
I am not looking to push the envolope that far. Be happy with 300rwkw on streets! I'm just in the process of talking to a mob called Custom cars to finish off all the work.
I'm getting
Tein Coil over
Slotted rotors
Oil cooler
Oil filter relocation
Apexi Power FC boost controler
HKS 740 injectors
Plenum
Exaust manifold
Throttle body
Alloy radiator
Bigger cooler with custom pipeing
Not to mention the container of Carbon we have coming from China. Sweeeeet.
You know of any good shops in S.E Melbourne who are reasonably priced????
Thanks for the advice anyway Nismoid. You obviosly know your shit.
Driveshafts will break long before the diff centre. The VL boys are running 9.50's with a stock R33 5-speed and single plate Jim Berry clutch now so your power expectations should be nothing to be concerned about.
They are smashing third gear eventually though, it all depends how hard you thrash it. 300rwKw will not be an issue and if you want a cheap way out with the rear end throw in a GT-R diff + larger shafts.
Edited by PJ.
  • 5 weeks later...
Cheers mate.
I thought i'd have a look at the oil in the box anyhow and f*ck me. I'm going to have to strat looking for a new box soon. Heaps of metal fileings and even a couple of little like clips. 4 of them. That would explain the crunch i get into 3rd & 4th on full boost. Man I hate this crap that comes and bites you in the ass.
Considering your Melb... some of your mods will get pretty nasty if you get EPA'd... going to cost you a LOT of money (many thousands) to get it passed.
There might be a smarter approach (tha potentially will save money/hassle) :blink:
That said, go visit RE Customs (Springvale), they have been doing great work and are probably the closest off the top of my head.
Here's a tip...... they're never complete!!!!!!!!!!!!!!!!!!!!!!!!
There might be a smarter approach (tha potentially will save money/hassle) :)
Cheers Nismoid.
I am doing my best to keep it all looking stock as possible. Well excluding the carbon mods. It is a bitch of a thing. The good thing is I'm in the Army reserves and My ID normaly gets me out of those sticky situations. lol. Another good thing is I do know of a dodgy russian workshop that'll pass anything within reason of course for $150. lol. Sh!t how do you think I got her on the road in the first place. lol.
Cheers heaps for your advice.
Currently I am having an absolute nightmare with my sound install. It's 5 days since the guy said it would be done. I went in last night and lost the plot. He was like what do you think of the boot. I said SHIT how the F*ck am I supposed to show this. Ahhhhhhhhhh. I wish I just paid the full amount and got a well known mob to do it.
Lesson learned there.
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
