hey guys
just wondering if i can run my car with no boost controller with my hks adjustable actuator?
my hiflow should be getting fixed soon and i dont want the hassle of getting caught with a boost controller.
i have heard that u can but being an internal gated turbo how much boost spike do you tend to get. or boost creep? (on my r33gtst)
much appreciated.
i did a search but couldnt find the answer i was looking for
thanks
You should be right running of an upgraded actuator, you'll only see the boost that the actuator is set too however.
It might taper off a little in the top end where a EBC might help hold boost
It might also build boost a little slower
But that are only a might, its not a certainty to occur, you might be totally fine :banana:
I have done this on other turbo engines with adjustable actuator, but not a skyline, basically the tightness (or preload) on the actuator will determine your max boost, the only big problem is if the line blows off the inlet pipe the actuator will keep the wastegut shut and you can overboost.
From experience...while these adjustable actuators do give some boost control...you still want a proper boost controller to hold the wastegate shut till you reach the desired level of boost...if not you'll have the wastegate creeping open as you build boost...set up properly a proper boost controller will give better response and also more midrange...
im running boost of the actuator..
on 16psi spikes to around 17-18 then drops..
when it was on 18psi spiked to 20psi :S
also feels a little laggy, can i get an ebc or do i have to get a stock r33actuator for the hks 2535?
Boost controller is definately way to go, just remember though your lowest boost setting will always be dependant on how the actuator is set, so you could loosen off your actuator to the 7psi mark, then with the boost controller you can set your high mark at whatever you want.
Would have to reccommend the gizmo IBC as it is simple to use, has 4 settings, with gain control and controls the boost really well. definately improve your lag factor
With the HKS adjustable actuators i think the lowest you can go is around 14psi...from there you can use a boost controller to raise the boost...remember...you want to keep the wastegate shut while you build boost to the required level before it opens...thats where the response and surge of midrange comes from...
At 18psi peak boost for example a car will make the same power but if you hold the wastegate shut till max boost you build boost quicker and hence fatten up the midrange...its all about area under the curve...
ok so set the hks actuator to as low as possible then get a ebc (dont have cash for profec b right now, ill search gizzmo) and set that to say 17-18ish..
would i need to get a retune?
You do not necessarily need to set the HKS actuator to as low as possible...i would use it to help control the spiking...if your boost is spiking too much then it would help to lengthen the actuator arm slightly...and if boost response is slow...then i would shorten the arm slightly as it probably shows its opening too soon...its a finicky process but once set about right then you're ready to use a boost controller of some sort to raise the boost...that way you'll get better boost control...
On a side note...i run the same turbo (HKS2535 on my rb20 and t makes about 220rwkw)...your peak power is definitely higher but i noticed that your power starts to climb alittle slower than mine even though mine's an rb20...not saying that anythings wrong but it might be worth looking into...something might be holding it back perhaps...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
