After spending literally $3500, on detailing, fitting, prepping, reshaping/moulding, painting...After 3 weeks of trouble and pain, its FINALLY FINISHED... I highly recommend Peter from Bodyform (If your in Sydney) to do any body kit work as the front bar was very bad quality and is now PERFECT thanks to him...
Do-Luck front bar, Bomex side & Rear.
:banana:
Edited by R33Turbo
I recommend you to get the bomex side and rear from peter @ bodyform (if ur in sydney)....
Tell him Austin sent you :devil:
The only place to get front bar is DMDtheimage in Brisbane, but get Peter to prep it for you cuz he does a perfect job.
:P lemme know how it goes
all up the bomex sides and rear, in AU$ is about $1100-$1300, not including shipping etc... so that is probably true
and the do-luck frnt wouldnt have been more than $600 $AU i belive, again not including shipping etc..
Edited by RusH_
Yes i could of gotten the genuine one but guess its just my lesson learnt thru the hard way...
BTW it was including refunds and lost money with shipping etc...then had to do detailing for $250 extra... so its all up $3500....anywayz im happy with itz ;)
Have no other angles taken at the moment...
Peter sells bomex kits but not do-luck cuz when he does its from the same guy "DMD" so wats the point?
its not factory cuz the coil overs were adjusted to sit taller than stock...however its not enuff for me to avoid scrapes...i can't drive it anywhere....i need to adjust it so it could sit taller and also change wheels to 19"....
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
