Hey all,
Did a quick search yesterday and didnt find much on where to get it in melb so had a look on there site closest was Bursons they are asking $143 for 4ltrs for lightweight shockproof.
Is there any better places to get it from or any better oils when i did an oil change in my GTS4 last time i just used penrite and i still got the synchro crunch on lazy changes.
Ive heard that it helps a lot with the crunching?
Any help would be great thanks David
https://www.sau.com.au/forums/topic/197434-redline-gearbox-oil/
I would be surprised if this does stop crunching (assuming it the same redline gearbox oil I used in the Evo). This oil is awesome when the gearbox is warm but makes the gearbox crunchy and notchy around town while it is cold. To cure the crunching, I use Castrol Syntrax which is thicker and more driveable around town.
Maybe different for skylines but didnt work for me as I also put it in for that purpose.
As for where to get it, Jeff at Techsport supplied and put it in mine and I dont remember it being this much.
  • 1 month later...
do a search covered before in fact there is a whole thread on it in General.
email harold. http://www.performancelub.com [[email protected]]
he will do you the best deal a snot retail pricing markup, check oil thread if you want more info. he is in Melb if you want pickup...$18/qt is pretty cheap.
If its std g/b I would just use MT90...not shockproof as its a GEAR OIL, not the same friction modifiers included as say mt90 or Syntrax or Syntrans...which btw are different. be fine.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
