hey guys the car im getting from melb has a turbo timer and alarm. Now turbo timers are illegal and i want it removed b4 i buy the car. So what im asking is how much would it be for a workshop to remove the Turbo timer and if the turbo timer is intergrated into the alarm how much would it be then?
oh and also price for removing the alarm coz im getting a better one?
Cheers
*Vinnie*
https://www.sau.com.au/forums/topic/197461-turbo-timer-uninstallation/
Turbo timer... when mine was going through compliance I just disconnected one plug + 1 ground wire and removed the unit. Easy.
Have the electrician remove the previous alarm when you have the new one install at the same time... usually works out cheaper.
Should be well under $100 to remove the turbo timer (it is a 30 minute job at worst). Or do it yourself and leave the wiring in there.
Agree - get the installer of your new alarm to remove the old one - while the car is in 1000 pieces is the cheapest and easiest way to remove the old, then reinstall a new alarm
for regency i just unplugged it from teh loom. and then hid the cables up near the steering column underneath the plastic (as mine was located near the steering column). At worst, just do this and leave the loom in. Then you can plug it in whenever you want.
I moved mine to the glovebox along with my boost controller so they werent obvious in the even i get pulled over.
cheers for the advice guys
yeh i wanna removie the turbo timer tho
i dont want to have one as it exposes the ignition wires n what not
i asked the guy im getting it from to ask his workshop how mucht heyd do it for and he sed $65\
is that too much or not?
cheers
cheers
Dude seriously........ Exposing the ingition wires doesn't matter..... If they want it they don't care about plastic, they smash it!!
Also there will be other things on the car that will get you defected anyways, But hey its your car and if you don't want it on there then i'm not gonna stop you!!
I've heard of more stupider things done with turbo timer so yeh.............
ahh k well then maybs i keeps it lol
i just want it to get registered
how do u get to put your car thru the cop shop on Sturt Rd as ive herd they only look for tin, lowering and obvious shit. so if im remove jst the unit it should be oka?
Yeh there was a thread about buying cars from interstate and getting them rego'd here and going thru Sturt!! I'm not sure exactly what times or days they are open but someone here will be able to tell you!!
Yeah Wed & Thur you can go to Sturt without an appointment for a Vin & Engine No inspection only if it's an interstate car.
Yup
+1
between 9am - 3am 2yrs ago, not sure about it now.
I thought it was tues and thursday only, but I cant remember, wed + thur is probably is !
rock up, wait, have all paperwork, and make the car look as stock as possible inside the engine bay / dash / outside body
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
    • I don't know what you should expect with an LS, but the oil pressure sounds terrible, sorry. As for the brakes, you can get fade from the pads not just the fluid, although generally that feels like a wooden block not doing anything while fluid feels like an oh shit there is no pedal so you can generally tell. What pads are you running front and rear?
    • Went over my datalogs on a whim and noticed a worrying combination of events. High RPM High Temperature Low Oil Pressure Knock Retard I bought some 10w-60 because I actually think this will be better going forward given track temp is 125C and 10-40 will actually be thinner in those environments. I know I had a leak but it's not entirely sure how much pressure loss can be attributed to that. The knock retard does correlate with all of the above. When it's not present oil pressure is higher. And by 'low' I mean at 6800 RPM the oil pressure was recorded as low as ~35psi pretty constantly. Which is obviously very not good. I'm hoping that thicker oil that ISNT LEAKING will result in a bit more pressure when I need it. Also in the last session I got a very spongy break pedal. I bled the lines as the car is on jack stand right now with the wheels off and I noticed... no air in the lines? Maybe the tiniest bit of tiny frothy bubbles for the first 0.1 seconds of bleeding the whole car? The breaks did come back to me after I backed off (and felt fine driving normally). Doesn't appear to be any leaks anywhere that I can see. Any thoughts on that?
    • Solution, run shitter tyres. Let wheel spin be your weak link 😛
