  • Replies 60
Posted Images
OMGHAITOYOU!! :rofl:
I am not sure what I am getting either, I already ahve a present under the tree and not cant guess what it is :sorcerer:
OMGHITOYOU as well, hope you are doing great.
Hopefully looking at coming to sydney in the new year for a weekend if i can get myself sorted.
Hope you have a wonderful christmas and new years and i will try to give you a call on new years.
So need to come and party with you in sydney!!!!!!! :bunny::bunny::(:banana:
well Xmas is my birthday as well so i freaking hope i get double the pressies....i already know that i am getting a helmet so far...but waiting for some cash to start flowing in lol...that way i can buy watever i want *EBC and a AM Fuel Pump*
im getting lauren a set of global knives (shes a cook not a killer) and a few other things
and lauren i already know what your getting me so you dont need to try and hide it, you suck at the secrect keeping haha
im also going to make your own account on here as it seems you use it as much as i do! consider it a xmas present :rofl:
kye
oh yeah and my car sucks :( and so do i
you should change your password kye
Edited by Import S13
i thought xmas was known as screwed out of a present day to you people :P must make planning bday stuff with people a pain in the arse seen as theyll all have there own xmas family stuff to do.
yeah sounds like im getting the $$ aswell. better that way, take advantage of the afta xmas specials
i dont do christmas.
haha, hate the whole commercial side of it, like the kicking back with family and having a few cold ones with dad (seeing as its about the only time of the year we get along), but mostly try to avoid it as much as i can, lol.
but ill be treating myself to a new bed, some new chucks, and a bottle of blue label.
Well not so much a present, but 2morow (24th) getting a R31 (hopefully all goes well) for myself.
Some shiz from the mrs
Lots of parts for the 31 (already have a few)
Money
And a lot..and i mean A LOT of ferrero roche (spelling?) and raffaello chocolates ! raff. ftmfw !
More stuff, cant remember now ;)
Merry xmas every1 !!
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
