hey just a quick question, a mate of mines has a r33 with aftermarket turbo, intercooler, exhaust, computer, 800hp fuel pump and lately its started to run rough, he had to put 95octane fuel in it the other day and thats when the probs started, weve changed the fuel filter and plugs but still when it stars to boost it starts sttuering like its havin fuel surge and backfiring, has any one else had similar problem? what should we check next? injectors or coils??? cheers
https://www.sau.com.au/forums/topic/197654-rb25det-problems/
thats exactly what my car is doing right now
it did it when i had my old 2 litre in it and i swapped in a neo and it still does it
the only things that are the same are the fuel pump,which i changed,the boost controller which i am changing tomorrow,and the maf.
so my guess is that the boost controller or the afm is not working properly,because it only happens under boost.
so try checking the boost controller and the maf
i will update if this thread when i figure the problem out,but i am fairly certain it is my old shitty manual boost controller sticking.
cheers!
yeh its got aftermarket ecu and recently had full tune by imports101, could it be a problem with the stock injectors? its my mates car, me and him both had to fill his skyline up and my ss up with 95octane wich our cars dont run too good on, after that i had similar probs with the ss but i changed the plugs and and me valkve springs at the same time n it came all good but the skyline just gettin worse
when you changed the plugs in the skyline, what plugs did you use?
and what gap?
May be a stupid question but have you got rid of the 95 fuel yet?
if not, maybe buy a bottle of good octane booster and dump that in the tank with the 95.. it should bring it's rating back up to 98 or so.
we didnt check the gap we just got some new ngk ones from repco and just assumed the gap would be fine, yeh we drained the fuel and ran injector clean through the engine and now are runnin it on 98octane ith octane booster,
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
