Thread - http://www.skylinesaustralia.com/forums/Vo...ee-t197550.html
Link to vote for meeeeeee http://www.nengun.com/member/ladybytes
It would be nice to win the boost controller, but there are some pretty popular/cool cars on there, so I will aim for top 10.
https://www.sau.com.au/forums/topic/197683-vote-for-meeeeeeeee/
hmmm do I tell you :wave:
LOL you win discounts and prizes just for being featured... so they say, I haven't done this before. But... if you get the most votes (not sure if thats most votes for Dec or all up) you can win the boost controller.
My first goal was top ten, now I want that controller LOL
Woohoo Im second on the featured list :banana:
Aren't you first already :(?
Woohoo I've advanced to the top of the featured list... but December still has some time to go.
How to vote - once you join (which takes about 30 seconds and you don't need to validate it) you click on the 5th star and you've voted (thats if you think its worthy of 5 stars). If you're already a member, you just sign in and click the 5th star.
Thanks for trying Tinks and Corinne
Corinne - I'll let you know as soon as it arrives :)
  • 3 weeks later...
Email from Nengun
Sent: Thursday, 3 January 2008 1:17 AM
To: Michele
Subject: nengun performance
Hello Michele
This is Brent from nengun performance. I would just like to say you came very close to winning the Trust B Spec II. If you added more about your car you probably would have won. Oh well, better luck next time. Scroll to the bottom of this e mail to see who the winner was.
Only Joking. Actually your vehicle was voted most popular, so you won the Trust Boost con . So if you give me your details I will send it to you asap. With your permission we would like to show case your vehicle on our front page. It would be nice if you could add some more details on the vehicle.
Best regards
Brent
Japan
www.nengun.com
THANKS HEAPS EVERYONE!!! :):):(
Now I need help with putting more info in about my car... I don't know what people want to know about the car, can anyone help?
just make up a list similar to this one...
Body.
Full ANDRA approved Cro-moly 6 point roll cage
Bodyform N1 style sideskirts
Top Secret rear underbody diffuser
Gannador aero mirrors
Garage saurus front lower lip
N1 front bar nostrils
Carbon fibre bonnet lip
D-speed clear indicators
clear side winkers
Full Spark Silver respray inside and out, including engine bay
Bodyform body striping
Interior.
Bride Zeta III FIA approved full bucket racing seat
Bride Brix II recliner passenger seat
Bride genuine rails (driver and passenger)
Willians 3 inch drivers harness
Willians 2 inch passenger harness
Carbon fibre rear interior trims
Carbon fibre console panel
Scuderia Racing 0-300kmh speedo
Autometer NOS gauge
Autometer boost gauge
Autometer warning light (low oil pressure)
Nitrous and line locker controls
Electronics.
Autronic SM4 ECU...fully optioned with logging, launch control, anti-lag, flat shift etc.(cur currently has Apexi ECU but Autronic will be installed after Dec. 07)
HKS twin power ignition
Splitfire ignition coils
Blitz ID3 boost controller
Blitz ID3 power meter
G-Tech PRO RR with laptop interface, software etc
Carel inlet temp meter (fully programmable switching outputs)
DiRTgarage 2wd/4wd switch loom
Driveline.
Cusco 1.0 way front LSD
Trust enlarged front diff cover
NPC twin plate custom race clutch (1000hp)
OS Giken 5 speed gearbox with upgraded input shaft
C's short shifter
Nismo gearbox mount
Nismo 2.0 way mechanical rear LSD
braided hydraulic clutch line
Full race line locker kit
Engine. (engine build by Croydon racing)
Block acid dipped, crack tested, deburred and specially modified for racing
Nissan new R33 crank race prepped by Croydon Racing (crossdrilled, grub screwed etc)
JUN conrods
JUN cosworth pistons
JUN rings
JUN oil pump
JUN conrod bolts
JUN main studs
Block drilled and tapped for 1/2 inch head studs
ATI race harmonic balancer
Performance metalcraft 9 litre race sump (swing gated baffles etc)
Tomei oil restrictor
Nismo engine mounts
Head. (head work performed and/or overseen by Croydon Racing)
Trust DRAG head gasket
Full race porting
Galleries enlarged and grub screwed
head machined for camshaft lobe reliefs
1mm oversize valves
bronze guides
JUN titanium retainers
JUN valve springs
JUN race cams (size and duration available to purchaser)
JUN cam cap studs
ARP 1/2 inch head studs
Tomei race buckets
Tomei valve shims
Tomei collets
Tomei inlet and exhaust gasket kit
Mines cam cover baffle kit
OS Giken cam gears
Trust timing belt
Turbo's.
HKS GT-RS turbo's (modified by Croydon racing)
Turbine housings coated in Hi-temp black ceramic coating
Compressor covers coated in Cerami-chrome ceramic coating
turbine housings ported and matched to manifolds and dumps
HKS 1.2 bar wastegates
HKS stainless manifolds Hi-temp black coated and ported and matched to head
HKS stainless dump pipes Hi-temp black coated and ported for increased gas flow
all turbo oil and water lines replaced with earls braided lines and fittings
Exhaust.
Trust front pipes (heat wrapped)
Trust full 4inch race system RO
Suspension.
HKS hyperdamper circuit coilovers
JIC rear upper camber arms
Nismo full rear arm kit (lower control arm, traction arms etc)
Rear sub-frame pineapple bushes
Tein front radius rods
Noltec front upper camber arms
Hicas rear cancel bar
Bracing.
Cusco front tower brace
Cusco rear tower brace
Auto-select front A pillar braces (rare)
Brakes.
Std GTR front brakes
Std GTR rear brakes
braided brake lines
Cusco master cylinder brace
Bendix ultimate pads
Fuel.
Bosch motorsport 040 in-tank swimmer pump
2 x Bosch motorsport 044 external fuel pumps
Performance metalcraft surge tank
custom perspex fuel system enclosure
Sard fuel pressure regulator
Blitz 1000cc injectors
Trust twin entry fuel rail
-6 braided fuel lines and Earls fittings throughout
twin Bosch motorsport fuel filters
Cooling.
Top Secret "super radiator"
Nissan N1 water pump
Trust oil cooler with filter relocator and thermoblock
Hypertune coolant overflow tank
Hypertune coolant header tank system with braided lines and alloy fittings
Gates radiator hoses
Intake.
Hypertune billet plenum with port matched runners
Hypertune 102mm single billet throttle body
Hypertune custom intake and intercooler piping kit
Trust DRAG 160mm twin entry intercooler
Twin Blitz blow off valves
HKS turbo to intercooler piping coated with cerami-chrome
HKS twin intake filters
Wheels and tyres.
Custom black R34 GTR rims with centre caps
Toyo street rubber
Std R32 GTR race rims
Mickey Thompson Street Drag Radials
Misc.
Full NOS 75hp wet nitrous kit including bottle warmer, gauges, brackets, 10lb bottle etc (never been used)
Sard battery box (in boot)
Battery isolation switch (front bar mounted)
Hypertune engine catch cans
UAS alloy radiator air guide plate
DiRTgarage mesh passenger headlight air intake
Engine bay braided hoses and lines
Trophies.
Winner Drag Combat round 1 Sydney Feb. 2004
Winner Sydney Autosalon Dyno challenge Mar. 2004
Winner Drag Combat round 4 Sydney May 2004
Winner Drag Combat National Series Champion May 2004
Runner Up Powercruise Dyno shootout
Winner Newcastle Autosalon Dyno Champion 2005
Winner Newcastle Autosalon Dyno 6 cyl 2005
Winner Newcastle Autosalon "tough as nails" 2005
Winner Newcastle Autosalon "driver with attitude" 2005
Winner Autosalon Final Battle Dyno 6 cyl 2005
Winner Autosalon Final Battle "tough as nails" 2005
Winner Autosalon Final Battle "driver with attitude" 2005
Winner Autosalon Final Battle "the unmistakeable theme" 2005
Winner Newcastle Autosalon Dyno Champion 2007
Winner Newcastle Autosalon Dyno 6 cyl 2007
Winner Newcastle Autosalon Dyno KW/Litre 2007
Winner Newcastle Autosalon "tough as nails" 2007
Winner Autosalon Final Battle "tough as nails" 2007
Media.
Autosalon Magazine Issue 24. 6 page full feature (Stacey)
High Performance Imports Magazine Issue 59. 6 page full feature (Paul)
High Performance Imports Drag Records List 7th position 4WD over 2400cc (Paul)
Extreme Magazine Issue 16 "Girl Torque" two page article (Stacey)
Upcoming full feature Ignition DVD (Paul)
Upcoming full feature High Performance Imports (Paul)
Mine is pretty much stock. I guess I don't know how to pull it apart i.e. wheels etc suspension etc
Must be something I can say that can make it sound as sexy as it looks (I'm allowed to be biased :))
Body.
clear side winkers
Interior.
Autometer NOS gauge
Electronics.
Driveline.
C's short shifter
Nismo gearbox mount
JUN conrods
JUN rings
JUN oil pump
JUN conrod bolts
JUN main studs
Nismo engine mounts
Full race porting
1mm oversize valves
bronze guides
JUN valve springs
JUN cam cap studs
Tomei race buckets
Tomei valve shims
Tomei collets
OS Giken cam gears
Trust timing belt
Turbo's.
Exhaust.
Suspension.
Bracing.
Brakes.
Std GTR rear brakes
braided brake lines
Fuel.
Cooling.
Intake.
Wheels and tyres.
Toyo street rubber
Misc.
Trophies.
Media.
WHAT!!!! No drink holder???!!.. you sir HAVE GOT to be joking!
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
