Thread - http://www.skylinesaustralia.com/forums/Vo...ee-t197550.html
Link to vote for meeeeeee http://www.nengun.com/member/ladybytes
It would be nice to win the boost controller, but there are some pretty popular/cool cars on there, so I will aim for top 10.
https://www.sau.com.au/forums/topic/197683-vote-for-meeeeeeeee/
hmmm do I tell you :wave:
LOL you win discounts and prizes just for being featured... so they say, I haven't done this before. But... if you get the most votes (not sure if thats most votes for Dec or all up) you can win the boost controller.
My first goal was top ten, now I want that controller LOL
Woohoo Im second on the featured list :banana:
Aren't you first already :(?
Woohoo I've advanced to the top of the featured list... but December still has some time to go.
How to vote - once you join (which takes about 30 seconds and you don't need to validate it) you click on the 5th star and you've voted (thats if you think its worthy of 5 stars). If you're already a member, you just sign in and click the 5th star.
Thanks for trying Tinks and Corinne
Corinne - I'll let you know as soon as it arrives :)
  • 3 weeks later...
Email from Nengun
Sent: Thursday, 3 January 2008 1:17 AM
To: Michele
Subject: nengun performance
Hello Michele
This is Brent from nengun performance. I would just like to say you came very close to winning the Trust B Spec II. If you added more about your car you probably would have won. Oh well, better luck next time. Scroll to the bottom of this e mail to see who the winner was.
Only Joking. Actually your vehicle was voted most popular, so you won the Trust Boost con . So if you give me your details I will send it to you asap. With your permission we would like to show case your vehicle on our front page. It would be nice if you could add some more details on the vehicle.
Best regards
Brent
Japan
www.nengun.com
THANKS HEAPS EVERYONE!!! :):):(
Now I need help with putting more info in about my car... I don't know what people want to know about the car, can anyone help?
just make up a list similar to this one...
Body.
Full ANDRA approved Cro-moly 6 point roll cage
Bodyform N1 style sideskirts
Top Secret rear underbody diffuser
Gannador aero mirrors
Garage saurus front lower lip
N1 front bar nostrils
Carbon fibre bonnet lip
D-speed clear indicators
clear side winkers
Full Spark Silver respray inside and out, including engine bay
Bodyform body striping
Interior.
Bride Zeta III FIA approved full bucket racing seat
Bride Brix II recliner passenger seat
Bride genuine rails (driver and passenger)
Willians 3 inch drivers harness
Willians 2 inch passenger harness
Carbon fibre rear interior trims
Carbon fibre console panel
Scuderia Racing 0-300kmh speedo
Autometer NOS gauge
Autometer boost gauge
Autometer warning light (low oil pressure)
Nitrous and line locker controls
Electronics.
Autronic SM4 ECU...fully optioned with logging, launch control, anti-lag, flat shift etc.(cur currently has Apexi ECU but Autronic will be installed after Dec. 07)
HKS twin power ignition
Splitfire ignition coils
Blitz ID3 boost controller
Blitz ID3 power meter
G-Tech PRO RR with laptop interface, software etc
Carel inlet temp meter (fully programmable switching outputs)
DiRTgarage 2wd/4wd switch loom
Driveline.
Cusco 1.0 way front LSD
Trust enlarged front diff cover
NPC twin plate custom race clutch (1000hp)
OS Giken 5 speed gearbox with upgraded input shaft
C's short shifter
Nismo gearbox mount
Nismo 2.0 way mechanical rear LSD
braided hydraulic clutch line
Full race line locker kit
Engine. (engine build by Croydon racing)
Block acid dipped, crack tested, deburred and specially modified for racing
Nissan new R33 crank race prepped by Croydon Racing (crossdrilled, grub screwed etc)
JUN conrods
JUN cosworth pistons
JUN rings
JUN oil pump
JUN conrod bolts
JUN main studs
Block drilled and tapped for 1/2 inch head studs
ATI race harmonic balancer
Performance metalcraft 9 litre race sump (swing gated baffles etc)
Tomei oil restrictor
Nismo engine mounts
Head. (head work performed and/or overseen by Croydon Racing)
Trust DRAG head gasket
Full race porting
Galleries enlarged and grub screwed
head machined for camshaft lobe reliefs
1mm oversize valves
bronze guides
JUN titanium retainers
JUN valve springs
JUN race cams (size and duration available to purchaser)
JUN cam cap studs
ARP 1/2 inch head studs
Tomei race buckets
Tomei valve shims
Tomei collets
Tomei inlet and exhaust gasket kit
Mines cam cover baffle kit
OS Giken cam gears
Trust timing belt
Turbo's.
HKS GT-RS turbo's (modified by Croydon racing)
Turbine housings coated in Hi-temp black ceramic coating
Compressor covers coated in Cerami-chrome ceramic coating
turbine housings ported and matched to manifolds and dumps
HKS 1.2 bar wastegates
HKS stainless manifolds Hi-temp black coated and ported and matched to head
HKS stainless dump pipes Hi-temp black coated and ported for increased gas flow
all turbo oil and water lines replaced with earls braided lines and fittings
Exhaust.
Trust front pipes (heat wrapped)
Trust full 4inch race system RO
Suspension.
HKS hyperdamper circuit coilovers
JIC rear upper camber arms
Nismo full rear arm kit (lower control arm, traction arms etc)
Rear sub-frame pineapple bushes
Tein front radius rods
Noltec front upper camber arms
Hicas rear cancel bar
Bracing.
Cusco front tower brace
Cusco rear tower brace
Auto-select front A pillar braces (rare)
Brakes.
Std GTR front brakes
Std GTR rear brakes
braided brake lines
Cusco master cylinder brace
Bendix ultimate pads
Fuel.
Bosch motorsport 040 in-tank swimmer pump
2 x Bosch motorsport 044 external fuel pumps
Performance metalcraft surge tank
custom perspex fuel system enclosure
Sard fuel pressure regulator
Blitz 1000cc injectors
Trust twin entry fuel rail
-6 braided fuel lines and Earls fittings throughout
twin Bosch motorsport fuel filters
Cooling.
Top Secret "super radiator"
Nissan N1 water pump
Trust oil cooler with filter relocator and thermoblock
Hypertune coolant overflow tank
Hypertune coolant header tank system with braided lines and alloy fittings
Gates radiator hoses
Intake.
Hypertune billet plenum with port matched runners
Hypertune 102mm single billet throttle body
Hypertune custom intake and intercooler piping kit
Trust DRAG 160mm twin entry intercooler
Twin Blitz blow off valves
HKS turbo to intercooler piping coated with cerami-chrome
HKS twin intake filters
Wheels and tyres.
Custom black R34 GTR rims with centre caps
Toyo street rubber
Std R32 GTR race rims
Mickey Thompson Street Drag Radials
Misc.
Full NOS 75hp wet nitrous kit including bottle warmer, gauges, brackets, 10lb bottle etc (never been used)
Sard battery box (in boot)
Battery isolation switch (front bar mounted)
Hypertune engine catch cans
UAS alloy radiator air guide plate
DiRTgarage mesh passenger headlight air intake
Engine bay braided hoses and lines
Trophies.
Winner Drag Combat round 1 Sydney Feb. 2004
Winner Sydney Autosalon Dyno challenge Mar. 2004
Winner Drag Combat round 4 Sydney May 2004
Winner Drag Combat National Series Champion May 2004
Runner Up Powercruise Dyno shootout
Winner Newcastle Autosalon Dyno Champion 2005
Winner Newcastle Autosalon Dyno 6 cyl 2005
Winner Newcastle Autosalon "tough as nails" 2005
Winner Newcastle Autosalon "driver with attitude" 2005
Winner Autosalon Final Battle Dyno 6 cyl 2005
Winner Autosalon Final Battle "tough as nails" 2005
Winner Autosalon Final Battle "driver with attitude" 2005
Winner Autosalon Final Battle "the unmistakeable theme" 2005
Winner Newcastle Autosalon Dyno Champion 2007
Winner Newcastle Autosalon Dyno 6 cyl 2007
Winner Newcastle Autosalon Dyno KW/Litre 2007
Winner Newcastle Autosalon "tough as nails" 2007
Winner Autosalon Final Battle "tough as nails" 2007
Media.
Autosalon Magazine Issue 24. 6 page full feature (Stacey)
High Performance Imports Magazine Issue 59. 6 page full feature (Paul)
High Performance Imports Drag Records List 7th position 4WD over 2400cc (Paul)
Extreme Magazine Issue 16 "Girl Torque" two page article (Stacey)
Upcoming full feature Ignition DVD (Paul)
Upcoming full feature High Performance Imports (Paul)
Mine is pretty much stock. I guess I don't know how to pull it apart i.e. wheels etc suspension etc
Must be something I can say that can make it sound as sexy as it looks (I'm allowed to be biased :))
Body.
clear side winkers
Interior.
Autometer NOS gauge
Electronics.
Driveline.
C's short shifter
Nismo gearbox mount
JUN conrods
JUN rings
JUN oil pump
JUN conrod bolts
JUN main studs
Nismo engine mounts
Full race porting
1mm oversize valves
bronze guides
JUN valve springs
JUN cam cap studs
Tomei race buckets
Tomei valve shims
Tomei collets
OS Giken cam gears
Trust timing belt
Turbo's.
Exhaust.
Suspension.
Bracing.
Brakes.
Std GTR rear brakes
braided brake lines
Fuel.
Cooling.
Intake.
Wheels and tyres.
Toyo street rubber
Misc.
Trophies.
Media.
WHAT!!!! No drink holder???!!.. you sir HAVE GOT to be joking!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
