Hi guys,
Do grounding kits really help? I have one given to me as a gift and was thinkin of fitting it to my NA R34. Will this be good for the car? Has anyone tried installing these and had good results?
and how hard is it to fit? coz all i have is a bunch of wires and I dont have a clue where they go LOL
Need help please
Cheers!
https://www.sau.com.au/forums/topic/197872-grounding-wire-kit/
Hi guys,
Need help please
Cheers!
I'm running a grounding kit and a voltage stabilizer on my R33 GTS25, there was't really a noticable difference, all I noticed was the car was a bit easier to start. But when I installed a grounding kit on our old R32 GTS-T there was a noticable difference, the head lights were much brighter, the car acclereated smoother and better, even the stereo sounded better. It seems that the grounding kit works on some cars but not on others
Edited by skyla
yeah
similar sort of thing - little box that you attach to ur battery that keeps a constant voltage from the battery
with the alternator spinning around, voltage fluctuates up and down - the stabiliser attempts to keep it flat
the results id seen were from a combination of grounding wire and stabiliser
Raizen do a stabilizer kit that apparently is pretty good when coupled with a grounder kit
yeah
Yup the Raizin by Pivot is a pretty decent grounding kit. but beware of fakes, lots of them floating around online
http://pivotjp.com/imitation/imitation-raizin-e.html
Also u can try the Hot Inazma system, heard its pretty good too
http://www.sigmaautomotive.com/HVS/hvs.php
You only tend to find a difference with these grounding kits on older cars, since wires break down over time and slowly reduce the amount of current they can flow. On a newer car like a r34 i wouldnt expect to see any difference what so ever
    • Impossible to remove the housing while turbo is installed on the manifold on the engine. So I have to do it anyways. I plugged it so there will not be any debris in there. Will vacuum aswell
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
