Was Driving yesterday and giving it a bit of a hard time then about 5 minutes later i was cruising and the oil pressure went to Zero and the Oil pressure light came on so i switched the car of straight away and just sat there for 5 minutes thinking why me! Fark and hell i hope i havent done any damage so left the car at my girlfriends house and now been stressing all day about it.
Im getting the car towed tomorrow to my mechanic to check the pressure and hopefully its alright its basically a new motor new turbos i had it dynoed last week to make sure everything is running safe abd not to lean and my mechanic said i had nothing to worry about the engine seems very healthy. Lucky it wasnt on hi boost was only running 10psi.
So pissed off i have had my gtst for 7 years not 1 problem had the gtr on the road for 3 days and was really enjoying it and now this! Words cant express how pissed off i am I was hoping to wake up this morning and i was having a bad dream but thats not the case.
Does anyone have any good news for me like maybe its nothing to major and im stressing about nothing?
Cheers any help appreciated.
Edited by wildr33gtst
https://www.sau.com.au/forums/topic/197954-rebuilt-rb26-help/
the oil pressure sender unit in the GTR is shite which makes the guage read all over the place. As for the oil light, thats a different story im pretty sure it runs independantly and if it comes on its not good. It could always be a electrical issue though
how was the car behaving? normally? weird noises ?
smart man for switching it off straight away. I know how tempting it would be to fire it up again just to 'see' what it's like. but sending it to the mechanic is the way to go.
did you check if it had any oil?
eitherway, if the engine has only been run for 3 days and went through that oil thats a problem by itself.
They'll just stick a mechanical oil pressure gauge on it and see what it reads. Hopefully its not a buggered oil pump
Edited by R34GTFOUR
It didnt go through any oil there is still 4.5L of Oil in there so its not low on oil and its not overfull and the oil looks alright, Its going to get towed to my mechanic at lunch time and we will check the oil pressure I just hope it didnt spin a bearing or something i will be so pissed considering it would have done no more than 2000kms. What would be the best case scenario? Is there any chance it couldnt have detsroyed my motor?
Best case is it's a problem with your oil pump and you replace that, which is in fact most likely the case I reckon.... If you turned it off quickly after it lost pressure, you might not have damaged anything at all >_<
Edited by TommO
yeah i hope so but it may not have been quick enough as soon as it happened i was around the corner from the misses house which was like 50 metres so i limped it there as i have had my gtst stripped twice when i left it out the front so wasnt going to do that with the GTR but i hope it didnt do damage that quick.
I checked the oil cap to see if there was oil in the head and there was a bit it is going to get picked up soon so i will find out shortly.
What an idiot i bought the car rebuilt so i expected him to change the oil pump if he rebuilt the motor i know i would have but i hope he hasnt taken a short cut and left the old peice of shit standard one in.
50m with no oil pressure should be okay, if it spun a bearing because of that i would be extremely suprised. I would say you will be ok, but thats if you lost oil pressure, theres still a chance that you just have a faulty sensor (although unlikely).
I had a mate, who wasnt very mechanically minded, and he tried to do a oil change on his skyline, anyhoo he didnt tighten the oil filter very well and it came off while he was driving. As you can imagine he lost all his oil, and no pressure and drove it a good 5mins home (stupid). All he did was top it up with oil, put a new filter on and even to this day its still going strong. As long as you werent belting up on it, it should be fine
Like i thought we checked it with a 2 mechanical Gauges and absolutely no pressure what so ever so definate pump failure, but going to have to drop the motor and check everything to make sure it hasnt done any damage to any of the internals.
I had a bad feeling as soon as that light came on i just hope i dont have to fully rebuild it again and i can get away with minimal. Going to purchase a N1 pump and the Tomei oil restrictor mod is already done and might as well put a sump baffle in to ensure this never ever happens to me again! How labour is it going to cost to get the motor in motor out on my car? Deciding whether to take it to a friends workshop to get it done but its a while away from where i live but if its cheap enough might take it to a work shop closer to me. Im trying to figure it out i just want it back on the road and its a crap time of the year to get anything done with christmas and new years.
If he had a spun bearing he would know it, she would have a very loud knocking. When you run the engine without oil I can tell you will do some damage to the bearings because there is no oil there so the bearing will be rubbing on the crank, if you take the big ends out you will see the markings on them . This doesn't mean that they are stuffed, in a normal ( none high performance engine) could run like that for years but in a boosted RB26, I don't know how long she will last .
Yeah why its out i will probably replace the bearings and make sure everythings that looks worn is replaced and it wont go back in unless its 100% fine. But im still hoping it was only the pump thats stuffed or maybe a squirter came loose just going to have to pull it out and find out. I'm not happy the reason i bought a rebuilt motor is so i didnt have to do this and for it to be reliable oh well shit happens.
What oil pump do you guys recommend my mechanic said the N1 pump and i am leaning towards that way at the moment also looking at JUN and TOMEI but there double the price, Can anyone shed some light on which one i should go for? cheers
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
