  • Replies 78
Does the phrase half cut mongrel enter anyone elses mind. I have no idea why people would basterdise a good car by adding a heap of fibreglass and bog to it. I hate any of those half this half that cars except the r34 front on a stagea as it seems to be the only conversion with any merrit just my opnion .
just my opnion
exactly...
I was thinking of doing this conversion myself until xmas time and rego sent me broke, but we'll see in the new year...
Its not as expensive (apparently) as youd think, ive had a word with the guys at Uras who've done a few of these conversions, and (once again, apparently) theres no real crazy modifications needed.
All that is needed for this to work is:
R33/34 conversion fenders - $300-400 roughly
R34 headlights - $5-600 plus
R34 bonnet - around $2-300 or go aftermarket which is around $500
R34 front bar - $1-200 or once again aftermarket $3-400
Budget around $2000 which should be enough. And if you can source the front panels which are the same colour as your car you are laughing!
Those conversion fenders are popping up all over the place now, so they are not that hard to come by. The only thing thats hard to find ive found is the R34 headlights, and if you can source them they are generally quite expensive...
If your going to do it, good luck and take many a picture!!!
:banana:
Edited by Musky
people do this because apart from the front nose all r34 look shit house. the rear is 10 metres off the ground and porpoise like a bitch. they are big fat bricks with no incling of aerodynamics.
atleast here u still have the nice flowing lines of a r33 with the sharp bulbous nose of the 34.
best of both worlds
u see how it looks low and sharp. where as if he bought a 34 is would look shit
u r a f**king idiot if u think that an r33 has better aerodynamics then an r34 then ur just a retard!!!!!!!
Saw something weird as today - a s15 body with a R34 head but with WRX doors...pretty hot....
Was this in the West again? :devil: That's some weird conversion.
Come on now... No need for that. We all know R32 has the best aerodynamics. :blink:
hhhmmmm. yea that explains why r34's have a severe porpoising problem (!)
r33's squat lower and are far more stable.
im just saying this from seeing hill climbs, talking to drivers
and driving an r33 and an r34.
i think the r33 has best handling and stability.
i have only had a short squirt in a r32 gtst, so i cant really comment on a r32, all i can say is if u have a r32 gtst your gay. soo guttless
Edited by r33cruiser
Cant really comment on drivability... but I think R33 looks much tougher.
"r33's squat lower and are far more stable.
im just saying this from seeing hill climbs, talking to drivers"
:D:devil:
sorry but i can't find the smiley face with the WTF sign.
:laughing-smiley-014: :laughing-smiley-014:
You bring a smile to my face at the end of a shitty day .
Someone find me the WTF sign please LOL!
Yeah, good to see that you're laughing... :(
But sorry to say, a R33 GTR does look tougher than the R34.... but then the R35 owns all... totally up to the eye of the beholder. :P
I have to agree with the R34 guys, the 34 looks better. The back end is pretty tall, noticed on a SAU cruise, but I'd still love one. That said, I think the R33/4 hybrid looks awesome, and is something different at least. Would like to see pics of one without the wide guards though.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
