Im going to go and buy a fairly low KM single turbo VG30 turbo on monday for $450 (to put on my rb20). What mods need to be done, at the moment i have a turbo back exhaust with a seperate dump, will i need to get a new dump pipe made up? Thats my biggest concern. Also does this turbo have a ceramic or steel exhaust wheel? And what else do i need to do to fit it on? What is the max boost i can run with it?
https://www.sau.com.au/forums/topic/19816-vg30-installation-onto-rb20-help/
u have to find out yourself if its got ceramic wheels or not,cause theres both in the vg30turbo range, Max boost id say around the 16psi mark with some good tuning and a fmic, but i rekon the turbo could take a little extra 2-3psi for short little bursts. And yes if u dont get the dump pipe with the turbo then you will have to get a dump pipe and your front pipe changed to suit, but if u get the dump with it,any exaust shop will be able to cut and shut a new flange to suit the new vg30 dump pipe. Also u might have to get some Bundi pipe and some fittings from a Hose/Hydraulic store :) hope that helps
The VG30 with good tuning should be ok for up to 1.2bar.
I think they all have ceramic exhaust wheels unless you go for a really old school VG30ET turbo.
I had a VG30DET turbo that was ball bearing and ceramic. It was definately a lot less responsive than the standard turbo and made full boost around 4000rpm.
I wasn't happy with it as it felt slower than the standard RB20DET turbo running 16psi so I pulled it back off.
Sure it rev'd a bit better up over 6000rpm but getting there was a bit slower.
It also felt like I really had to give it heaps of shit just to hit boost in first gear, so basically expect to have almost no boost in first.
  • 5 months later...
Stick with the RB25 turbo on the RB25. The VG turbo isn't as good as the RB25 turbo. The VG has a smaller compressor so it is a step backwards.
TO be honest I would buy a RB20 turbo over a vg30 for the street. The VG is to laggy.
That's good to know.
I wanted to stick a VG30 on my RB25 but it seems I can only get the roller bearing models.
May as well stick with the RB25 if it's laggier.
T.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
