Yup read that thread, we did my conversion in a weekend and I think the only modification we had to perform was on the powersteering pump bracket (on the 20 the top bolt goes to the head and the bracket has a longer boss for that one, had to cut it flush with the two lower bolts as on the 30 all 3 bolt to the block). Other than that, we just swapped everything off the 20 and bolted it all back in.
Oh you may have clearance problems with your front pipe.. mine hung pretty low to begin with and some slight massaging of the floor pan at the front gave me enough clearance to pass the pits :rofl:
Edited by bubba
https://www.sau.com.au/forums/topic/198411-rb30-conversion/#findComment-3545038
Currently running a standard s1 33 turbo at 12psi while I collect the rest of the bits to put the GT35R on :(
Haven't had it down the quarter yet as I've been ironing conversion wrinkles out :D she's only making 183rwkw with the little turbo anyway.. nothing really special :(
https://www.sau.com.au/forums/topic/198411-rb30-conversion/#findComment-3556615
hey mate if your interested we are building 3 atm all for R32s
im sure we can do another one for you with out any issues
drive in/drive out complete package designed around your budget
PM me if your interested
https://www.sau.com.au/forums/topic/198411-rb30-conversion/#findComment-3556630
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
