The following R33 parts...
Greddy intake fit to neo?Yes
Clutch for fits to neo?No, same as late 32/33 gtr
Forged pistons for r33 fits to neo?No
Exhaust manifold fits to neo?yes
Nissan OEM gasket kit fits to neo?should
That's all :P
Edited by Adriano
Greddy intake manifold needs to be modified..not a perfect fit
bolts straight up perfectley with no mods, wiring and shite needs mods.
http://www.skylinesaustralia.com/forums/In...eddy+plenum+r34
http://www.skylinesaustralia.com/forums/Gr...=plenum+r34+gtt
And another question...
I would like to put wisecos because they are cheap..
What compression I will have with stock headgasket with
R33 RB25 pistons?
RB26 pistons?
Here there are the spec of the pistons... I don't know how to calculate the ratio so anyone how knows please let me know!
http://www.wiseco.com/PDFs/Catalogs/SC08/N...aruToyotaVW.pdf
R33 RB25 pistons?
RB26 pistons?
Neither are appropriate, you will end up with >10:1 comp.
R34 neo throttle body is basically the same as r33 except it has the TCS butterfly on the front, no probs fitting a Q45 one to the greddy. IMO save the $1300 for the greddy/Q45 and do the motor properly, maybe with an rb30(then you can just use rb30ET forged pistons to give you high 8's:1 comp)
Edited by Adriano
Anyone know what pistons I can put to NEO??
Wiseco don't have neo pistons?
EDIT
Adriano are you sure? In this post they say Abo Bob said that will be 8.75:1!
http://www.skylinesaustralia.com/forums/Rb...rged&st=20#
RB25 and RB26 aren't different high pistons? Who knows to calculate the compression? Always with stock gasket!
For both 25 and 26 pistons!
Edited by GreeceS13
NEO has a smaller combustion chmaber so R33 pistons will produce a high ( as in too high ) a comp ratio.
Exhaust manifold is the same stud pattern.
OEM gaskets - some will be different, like valve stem seals etc - but most should be same as R33
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
