Hey, i had this problem with my 32, coz i got a half cage and no back seats. Cops yellow licky'd me and told me told i needed to register it as a 2 seater. So i took it to Pits in Kelmscott, told me i COULDNT do it. Confused i called the Technical Section in Welshpool, told me it was all sweet, told me to check the National Code of practice (linked)
http://www.infrastructure.gov.au/roads/saf...n/vsb_ncop.aspx
Check the pdf file labled, LK Section to do with Seating and occupancy. basically, if you plan on PERMANENTLY removing back seats, you need to seal up any holes left by the removal of back seats, boot still needs to be seperate for cabin (ie parcel tray and metal plate need to stay in place) and then fill out a form saying you wish to register it as a 2 seater. Might need a engineer or Mech to sign sayin, yes it meets the requirements on the check list. Just read the PDF file, pretty self explanatory. All the best with that.
I ripped mine out (s15) for collie, then when I went to put them back in, I couldn't get the seatbelts to come out... Seats were in tho. Got stickered one night for bald tyres and had to go over. Rather than f**k around with the seatbelts, I figured I'd go the 2 seat option so that if I needed to pull the seats out again, I could, legally.
ALL bolts/brackets/anything else sharp/not a part of the body needs to be removed and you need something to block the boot from the cabin (I used MDF drilled into the body). I think that's to do with fumes/possibility of explosion, but I'm not sure.
My car is still rego'd for 4 seats, but have the permit for no rear seats. So in the event I want to take the whole family out, I can throw it all back together (with seatbelts) and still have 4 people in the car legally. In the event I want to go to collie and load up 10 tyres, I can rip it all apart and do that legally.
Only thing is, I think you'll find if you have the back seat in, you will need to have the seatbelts in. So even if you have the permit and get pulled over, not having seatbelts for seats is a yellow, where as if the whole lot wasn't there you'd be fine.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
