  • Replies 94
Posted Images
the stock extractors are cast. all the primaries, ie th tubes from the outlet on the head are different lengths. in terms of torque its advantageous to get all the primary's as long as possible, and equal in length. th reasoning being that it evens out the pressure wave "pulse" when the exhaust gas is vented from the combustion chamber.
however the larger diameter the tube..the lower the pressure..and you want a decent pressure wave to help "suck" the exhaust gas out of the combustion chamber at the end of the stroke, as the drop in relative pressure between the header and the combustion chamber produces this "scavenging" effect.
so as you can se from this its a balancing act. too big a tube drops the pressure and then you get a very flat engine with no power. to small and it wont flow the gases as quickly as it could.
the exact "best" set up for an rb25 de or rb20 would need to be computer modeled and then built from scratch, and even then beecause of space constraints ultimately the tubes will perhaps have to be less than the theoretical idealas they have tofit the car. essentially the d12's allow the car to perform closer to its mechanical and theoretical maximum potential, though probably not at it.
if that makes sense.
Edited by Hesh
thanks for the write up Hesh, appreciate it, was helpful :banana:
the extractors i stated above are the ones I have (they are smaller diametre d12), I just got them but havn't fit them on yet. Seeing how most people ordered 2.5'' outlets, compared to my 2'' is there much difference??
no probs mate. sorry i cant be specific about the figures and benefits of one ovr th other. thing is here in the uk most skylines as turboed so not much info exists at the present regarding tuning options for the de's as not many people have done it to find out! ....so if ya fit your 2inchers and collect all the info you'll be one of the first .....
I'm just curious, is it possible to have JUST HALF of the headers HP Coated? since the only problem (that I am aware of) is keeping the heat out of the engine bay. i.e, JUST coating the primary pipes and a bit of the secondarys and just some cheap heat wrap around the rest of the headers?. Enough so you could see the bling and coated enough away from the intake pipe, you guys get what I'm trying to say? lol.
I know you would end up with ugly ass half cross breed HPCoated extractors/ heat wrapped lol but you'll only see the top of the extractors anyways.
Would this be possible and cheaper?? or HPC workshops don't do these kind of coatings? or is there some other factor involved?
Edited by OoskylineoO
im reaching a bit here but id wager that it would create a hotspot at the join of the treated and untreated portions. which may lad to complications. id just simply heat wrap and paint the whole thing as that's essentially doing the same as the ceramic coating.
it isnt just about keeping heat out of the engine bay, although that's a factor. if the exhaust gasses cool to quickly (i.e. via convection of heat from unwrapped/non treated pipes) they slow down...thus leading to a drop in power similar to too large and exhaust bore. keeping the exhaust gasses hot until out of exhaust means a better breathing engine.
mines still standard mate. its taken me ages to track down any headers for th rb20/25de's. like i say evrything still turbos here. out of a whole forum of like 3000 plus theres five interested in this group buy...cos no on bothers withthe NA's......but i aim to change that.
Edited by Hesh
Hey just a question about my setup mentioned earlier....
its been about a month since i got extractors ans exhaust done but recently i noticed its quite quiet..not as much drone or rumble....any idea why????....anything to do with fuel ...or possibly cause it has been driven in close too a week
...or could it be im now going deaf compared to how loud it was at the start lol
  • 4 weeks later...
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
