Evening all
thinking of heading up to a drift night at Archerfield or QR in my N/A R33 is it worth taking a non-turbo up there are there many haters?
And if i were to go how much would a day/night cost me (never been B4) prob need tyres aswell
https://www.sau.com.au/forums/topic/198972-drift-day/
Hey mate..
is it a practice day?.. or a competition?
If its a competition then id stay clear if you havent drifted before.. If its a practice.. then go for it!.. Its well worth the $100 - $160 (depending on who and where the track day is with)!!! Its awesome amount of fun!..
There isnt any NA hate when it comes to drifting.. you can drift an NA and I have seen people do it just as.. if not better in an NA than some turbos!..
If its your first time drifting I wouldnt worrie too much about tyres.. new kids usually dont end up in blisteringly long smokey drifts on the first drift event.. but then again.. you could be a quick learner.. ;)
https://www.sau.com.au/forums/topic/198972-drift-day/#findComment-3549623
Thx for that mate
It would definetely be a practice day which track would u recommend for a learner?
Do u need to bring ur own petrol in case u run out?
Just need to know all the little things even if they seem stupid.
https://www.sau.com.au/forums/topic/198972-drift-day/#findComment-3549844
Seeing as your in QLD.. and Im in NSW.. I got no clue on tracks up there mate.. sorry..
Have a look at Initial Dirft Australia.. or Aus drift.. or a drifing forum where you can find details where drift specific events are held in your area..
Yes.. petrol is a good idea as you will be thrashing your car all day.. similarly.. poeple can and do go a little crazy on the weight saving factor at track events and completely strip their cars interior.. its not necessery though..
Tools are a good idea if something roots itself.. and fluids.. fluids are a good idea.. coolant.. brake fluid.. oil.. water..
This is a typical preparation for a circuit trackday.. so its a little more hardcore than a first drift event.. really.. just a very basic box is needed with a couple of essentials..
Why not have a look as a specator before you do your drift day?.. have a walk through the pits and see what others bring.. (do bear in mind poeple bring hardcore back up as there are quite skilled drifters that acctualy need the support).. but i think you'll be fine for a first timer with the very basic things..
Edited by GTS4WD
https://www.sau.com.au/forums/topic/198972-drift-day/#findComment-3550122
Who cares what you're driving, whether its NA or FI? As long as you're out there enjoying the sport like everyone else, that's all that should matter.
People who reckon that drifting is an FI-only sport can go get f**ked, and have a chat with Katsuhiro Ueo. Tsuchiya's hachi is NA as well.
https://www.sau.com.au/forums/topic/198972-drift-day/#findComment-3551036
An N/A track spec hachi that weighs 700-800kg~ is a little different than a stock N/A R33 in street trim.
Weld the standard diff as a start, and if you can afford it buy some adjustable coilovers (or swaybars.. or both) and castor arms -
Also look at running some skinny tyres on the rear to make it easier to break traction.
You'll have to be alot more aggressive with your car and the clutch/handbrake to make it slide and keep it going, but most importantly have fun and don't worry about what other people think, more often than not they'll be more than happy to lend some advice :banana:
https://www.sau.com.au/forums/topic/198972-drift-day/#findComment-3551139
You're not getting my point.
homedog56 was wondering if it was worth taking his NA car to drifting or there'd be too many "haters". I was pointing out that there are plenty of famous NA drifters out there.
https://www.sau.com.au/forums/topic/198972-drift-day/#findComment-3551166
If you are worried about your first time out there on the track - maybe try and find some skid pan days first of all?
Skid pan would be all wet and you really do get to learn alot about the car, how it slides, how it behaves etc and theres plenty of room if you have a "spin"!
https://www.sau.com.au/forums/topic/198972-drift-day/#findComment-3552224
yeah try a skid pan day first, learn how your car handles etc.
then next you can step up to a track day. even better if the track day is a wet day or when its raining, makes it abit easier for a NA to slide.
you can pretty much drift anything whether it be NA or FI.
its just how much balls you got.
in an NA, you gotta full shift the weight to get it to kick out unlike FI you just tap the throttle.
unless your NA is some torquey mofo :P
im yet to go out on my first track day as my car isnt really setup for it yet but hopefully within 4-6 monthts it will have the basic suspension components to get its as$ out on the track and try and do some skids..
https://www.sau.com.au/forums/topic/198972-drift-day/#findComment-3560230
yer im pretty keen to hit up a day and watch first anyway
wen is the next one on
at either track?
and im gettin a exedy heavy duty clutch intsalled on monday
just wanting to know some ppls thoughts and how they hold up under drifting conditions
https://www.sau.com.au/forums/topic/198972-drift-day/#findComment-3562969
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
