im wondering what is the next setup for my R33 GTR
here's my setup so far
i have APEXI AVCR boost controller...boost reaches 1.5 bar, lowering the boost after a interooler pipe remove the other night
stock garrett twin turbos with ball bearings (i think)
APEXI SAFC
TWIN HKS SSQ BOV
BLITZ Exhaust
APEXI POWER intake
stock ecu
(I haven't opened my engine and check the cams...and inner parts, i haven't added performance parts yet, this is what iv gotten when i bought the car from japan) with the HKS BOV, what could be the limit of the boost of this setup???thnx
https://www.sau.com.au/forums/topic/198994-next-setup-for-my-r33-gtr/
Power FC if you can get one.I think ive seen a few for sale in the for sale section.
Haltech are good but a bit expensive.
As for clutches a good upgrade is a ceramic cushion button.Can handle up to 300ish kw and are good for daily driving.
I have given mine a bit of a caining, a few passes down the quarter.Still feels like it did when it was new.
1.5 bar boost and stock turbos ???? I wonder how long she is going to last. If I was you, I would back off the boost to under 1 bar until you replace the turbos .
Stock R33 GTR turbos are not ball bearing .
Yep next thing i'd be doing would be a computer and a tune, most people round here use PowerFC's and regardless of what people tell you APEXI do still make them and they are readily available for the Rb26.
Also if you are unsure of what turbos you've got best to keep them under 1bar for the time being, as the others have said...
i haven't touch the settings oh my avcr, the whole setup is from japan, it reaches to 1.4 and 1.5 bar from my avcr, could it be possible that the cause of high boost is because i removed the muffler? i only left the resonator?? i already checked my turbos, its a GARRETT M24 A/R42 , i tried to spin it with my fingers and it stops about 2 to 3 secs...so maybe its a ball bearings? were can i find the power fc ecu? and how much?
So, because your car already appeared to be running '1.4-1.5 bar' when it arrived from Japan you assumed it was safe to continue doing so?
Im surprised your turbos haven't combusted and lunched your motor
Just out of curiosity, when a turbo blows itself to bits like your suggesting this one could, what would "lunch" the motor?
Is it possible for the turbo particles to get through the intercooler? It doesnt look like theres alot of room for bits to get through!
(i dont know a great deal about turbos blowing up.. thought this might be a good place to ask :banana: )
Search is your friend but ....... when a RB26 ceramic exhaust wheel turbo goes it is generally spinning fast enought that it sends ceramic bits everywhere including back down the exhaust manifold and potentially into the engine through an open exhaust valve - hence everyone's warnings. The stock turbo's are known for doing this with increased boost and age.
Cheers
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
